Have you seen my edit above?
Just saw it now @ScruffR ! I’ll try this too after @peekay123’s method
I will eventually need to send more than 64 bytes at a time, I just didn’t think it was this complex you know?
Not that it truly is, but I mean my understand was: put # of bytes into buffer, read bytes out of buffer reducing how many were in there making room for more bytes to put in, but I guess since they aren’t synced then things can get messy?
ALSO I potentially like the idea of local compilation to increase the Serial Buffer size.
I do sort of get the idea
Do I implement this using switch() ?
@UST, yes you can.
