I cannot flash binaries serially. It shows this error:
particle flash --serial system-part2-0.6.2-photon.bin
! PROTIP: Hold the SETUP button on your device until it blinks blue!
? Press ENTER when your device is blinking BLUE
! serial:
Error writing firmware...Timed out waiting for initial response from device
undefined
However using DFU, it worked. But then the bootloader binary cannot be flash serially, shows the same error above!
Any other option except upgrading the system firmware?
Did you do the step of upgrading to 0.7.0rc3 first? You won’t be able to flash the bootloader until you do that first. You don’t need to stay on 0.7.0rc3, but you need to do that first otherwise you can’t downgrade, unless you do it by JTAG/SWD.
@rickkas7@ScruffR, I couldn’t degrade the bootloader. But Upgrading the firmware solved the issue. Now I can successfully use all DFU as well as serial CLI commands. Thanks a lot.
