TFT Display with Custom Fonts
I have gone back to my test sketch to use pinSetFast and pinResetFast and I am now finding it impossible to get the following to build. There are all sorts of ARDUINO not defined issues, then SPISettings then…
The includes in my sketch look like this
#include <Adafruit_HX8357_RK.h>
#include <Adafruit_STMPE610_RK.h>
#include <SdFat.h>
#include "Adafruit_ImageReader.h"
#include "FreeMono18pt7b.h"
#include "FreeMono9pt7b.h"
There seem to have been some changes in these libraries, so I deleted and reinstalled:
dependencies.Adafruit_HX8357_RK=1.0.8
dependencies.Adafruit_STMPE610_RK=1.0.1
dependencies.SdFat=1.0.16
dependencies.Adafruit_ImageReader=1.0.9
dependencies.Adafruit_GFX_RK=1.5.6
The errors suggest there is some mismatch -
In file included from /Users/wjsteen/Documents/Intelligent_Furniture_Project/VSC_Projects/zioxi_locker_ui/lib/Adafruit_GFX_RK/src/Adafruit_SPITFT.h:26:0,
                 from /Users/wjsteen/Documents/Intelligent_Furniture_Project/VSC_Projects/zioxi_locker_ui/lib/Adafruit_HX8357_RK/src/Adafruit_HX8357.h:36,
                 from /Users/wjsteen/Documents/Intelligent_Furniture_Project/VSC_Projects/zioxi_locker_ui/lib/Adafruit_HX8357_RK/src/Adafruit_HX8357_RK.h:4,
                 from /Users/wjsteen/Documents/Intelligent_Furniture_Project/VSC_Projects/zioxi_locker_ui/src/zioxi_locker_ui.ino:8:
/Users/wjsteen/Documents/Intelligent_Furniture_Project/VSC_Projects/zioxi_locker_ui/lib/Adafruit_GFX_RK/src/Adafruit_GFX.h:6:0: warning: "ARDUINO" redefined
  #define ARDUINO 157
In file included from ./inc/SPI.h:1:0,
                 from /Users/wjsteen/Documents/Intelligent_Furniture_Project/VSC_Projects/zioxi_locker_ui/lib/Adafruit_GFX_RK/src/Adafruit_SPITFT.h:25,
./inc/Arduino.h:16:0: note: this is the location of the previous definition
 #define ARDUINO 10800
/Users/wjsteen/Documents/Intelligent_Furniture_Project/VSC_Projects/zioxi_locker_ui/src/zioxi_locker_ui.ino:73:62: error: use of deleted function 'Adafruit_HX8357::Adafruit_HX8357(const Adafruit_HX8357&)'
 Adafruit_HX8357 tft = Adafruit_HX8357(TFT_CS, TFT_DC, TFT_RST);
In file included from /Users/wjsteen/Documents/Intelligent_Furniture_Project/VSC_Projects/zioxi_locker_ui/lib/Adafruit_HX8357_RK/src/Adafruit_HX8357_RK.h:4:0,
/Users/wjsteen/Documents/Intelligent_Furniture_Project/VSC_Projects/zioxi_locker_ui/lib/Adafruit_HX8357_RK/src/Adafruit_HX8357.h:127:7: note: 'Adafruit_HX8357::Adafruit_HX8357(const Adafruit_HX8357&)' is implicitly deleted because the default definition would be ill-formed:
 class Adafruit_HX8357 : public Adafruit_SPITFT {
/Users/wjsteen/Documents/Intelligent_Furniture_Project/VSC_Projects/zioxi_locker_ui/lib/Adafruit_HX8357_RK/src/Adafruit_HX8357.h:127:7: error: use of deleted function 'Adafruit_SPITFT::Adafruit_SPITFT(const Adafruit_SPITFT&)'
In file included from /Users/wjsteen/Documents/Intelligent_Furniture_Project/VSC_Projects/zioxi_locker_ui/lib/Adafruit_HX8357_RK/src/Adafruit_HX8357.h:36:0,
/Users/wjsteen/Documents/Intelligent_Furniture_Project/VSC_Projects/zioxi_locker_ui/lib/Adafruit_GFX_RK/src/Adafruit_SPITFT.h:118:7: note: 'Adafruit_SPITFT::Adafruit_SPITFT(const Adafruit_SPITFT&)' is implicitly deleted because the default definition would be ill-formed:
 class Adafruit_SPITFT : public Adafruit_GFX {
/Users/wjsteen/Documents/Intelligent_Furniture_Project/VSC_Projects/zioxi_locker_ui/lib/Adafruit_GFX_RK/src/Adafruit_SPITFT.h:404:9: error: union member 'Adafruit_SPITFT::<anonymous union>::hwspi' with non-trivial 'constexpr Adafruit_SPITFT::<anonymous union>::<anonymous struct>::<constructor>(const Adafruit_SPITFT::<anonymous union>::<anonymous struct>&)'
       } hwspi;                     ///< Hardware SPI values
/Users/wjsteen/Documents/Intelligent_Furniture_Project/VSC_Projects/zioxi_locker_ui/src/zioxi_locker_ui.ino: In function 'void setup()':
/Users/wjsteen/Documents/Intelligent_Furniture_Project/VSC_Projects/zioxi_locker_ui/src/zioxi_locker_ui.ino:85:19: warning: unused variable 'stat' [-Wunused-variable]
   ImageReturnCode stat;       // Status from image-reading functions
ARDUINO issues I can fix but the use of deleted function I really can’t see the problem.
