This is something that’s on the roadmap, but there isn’t a way to set that yet. I’m trying to find a way where the syntax isn’t awkward :\ The most obvious solution to me is to add another property, that lets you set the types of other properties, or a meta property. If you were going to add the ability to set a property that should be treated as a number (no quotes when making the request), how would you want to specify that?
Thanks,
David
