[SOLVED]Jquery getJSON calls returns 404 error
Are you sure your variable name is correct?
If you want to make sure your setup is correct (other than that page), you can try requesting your variable here (and seeing if it shows up in the first place).
If you can’t see it in the browser by pasting that link, it’s not going to work in your javascript either.
