Take a close look at this post, might help ![]()
I've tried 2 resistors: brown-black-orange (from Adafruit: 10k) & brown-black-red (1k). I also rewrote the example to make it more understandable (to me): But there's no way to sensibly include CPP text/
Here's the printout:
Press any key to start.
DHT Example program using DHT.acquire and DHT.aquiring
LIB version: 0.2
0: Retrieving information from sensor: .............. (dots represent 10ms delays for DHT.acquiring() in a loop)
Read sensor: Error
.ISR time out error
1: Retrieving information from sensor: ...............
Read sensor: Error
.ISR time out error
HI
Seems I have the same problems.
The code is using the #include āPietteTech_DHT/PietteTech_DHT.hā lib, and is identical with the one above.
Tried:
- different resistors
- different DHT22
- different Pins (D2, D5)
- 3,3V and VIN
I always get the ISR timeout error. Any new ideas from you guys?
Thanks I appreciate your help.
Lukas
Hi guys - found the error.
It was my stupidity, new breadboard and I powered it wrongā¦
Hi!
Iām having issues as well. Hereās my setup:
- 10k resistor
- Using the exact PietteTech code shown above, and #include āPietteTech_DHT/PietteTech_DHT.hā library
- Using pin D3
- Code verifies and flashes successfully on web IDE
But I keep getting a āfailedā data error on the dashboard:
Many thanks!
This āfailedā message should not bother you too much. Itās not too uncommon to get a flash failed message while to code still got flashed fine.
You could always try to flash in Safe Mode too.
If you run the PietteTech code from post #1, this bit of code requires you to connect via serial and send a byte to the device in order to get the program running
while (!Serial.available()) {
Serial.println("Press any key to start.");
delay (1000);
You could always add a timeout too
while (!Serial.available() && millis() < 30000)
{ // wait for keypress or 30sec timeout
delay (1000);
Thatās already incuded in the code above, at the beggining of setup(). Inlcuding the timeout doesnāt make a difference. Any other ideas?
What exactly is the problem then?
Since you only mention the spark/flash/status failed issue, which I said is not really a problem since it is a false positive.
Have you tried checking the serial output? No data is supposed to show up in the dashboard, so youāll be staring at that for a while if youāre waiting for thatā¦
Hence these earlier comments ![]()
I guess I donāt know how to read data from and store it somewhere (numerous, etc.) to trigger other events. I assumed I couldnāt read data since the dashboard showed āfailedā. Apologies if this is too basic. Thanks again!
Is there anything we can help you with?
If you read the docs and still canāt wrap your head round it, we can help, but the basic functions listed in the docs should already mean something to you.
The PietteTech code uses two sensors A and B
I have two sensors and tried for the longest time to get a reading on a single sensor on port d2
So just for giggles I set up the other sensor on d3 and viola! I get readings on that port but not d2.
So does that mean d2 is bad? At $19 ... is this a warranty thing?
FYI... I flipped sensors and the issue did not follow the sensor ... it stayed with the port. So I know it's the Photon.
What to do? Is there a way to test the port?
@Walt750, interrupts on pin D2 are shared with pins A0 and A3 as per documentation. If you have interrupts set on those pins, that may be the issue.
Thanks Peekay123 ⦠I will check it out.
This is the only program that Iām running though - Iāll take a look ā¦as far as Photonās and Arduinoās I love them.
Where was this stuff when I was kid?
