Singletact reading data (arduino)
https://community.particle.io/t/fsr-code-with-excel-plx-daq/44795/26
Hey guys,
i need help again :wink:
How can i convert the Sensor Data Readings like (256) to 0,5V automatic or to Force with Arduino ???
in datasheet of this Sensor says that from 256 to 511 ist = from 0,5 to 1,5 V (look pic)
then i want to convert the Sensor Data Readings to Pressure but im getting 0,0 why ??
this ist the code
#include “DHT.h”
#include <SD.h>
#include <SPI.h>
#define DHTTYPE DHT22
const int DHTPin = 2; // what digital pin we’re connected to
DHT dht(DHTPin, DHTTYPE);
float Pressure;
#include <Wire.h> //For I2C/SMBus
File myFile;
void setup()
Wire.begin(); // join i2c bus (address optional for master)
//TWBR = 12; //Increase i2c speed if you have Arduino MEGA2560, not suitable for Arduino UNO
Serial.begin(9600); // start serial for output
Serial.flush();
Serial.println(“CLEARSHEET”);
Serial.println(“LABEL,Date,Time,Humidity [%],Temperatur [*C], Sensor_Data, Pressure [mmHg]”);
// SD Card Initialization
if (SD.begin(10))
Serial.println(“SD card is ready to use.”);
} else
Serial.println(“SD card initialization failed”);
return;
//Write myFile Header
File myFile = SD.open(“st.txt”, O_CREAT | O_TRUNC | O_WRITE);
if (myFile)
String header = “Humidity [%],Temperatur [°C], Sensor_Data, Pressure [mmHg]”;
myFile.println(header);
myFile.close();
Serial.println(header);
} else {
Serial.println(“error opening st.txt”);
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
Serial.println(“PPS UK: SingleTact sensor value in PSI. \n(resembles PC executable display)”);
Serial.println(“Refer manual for any other calculation.”);
Serial.println("----------------------------------------");
dht.begin();
void loop()
//////////// Reading temperature or humidity //////////////
float h = dht.readHumidity();
float t = dht.readTemperature();
if (isnan(h) || isnan(t)) {
Serial.println(“Failed to read from DHT sensor!”);
return;
Serial.print(“Humidity [%]: “);
Serial.print(h);
Serial.print(“Temperatur [°C]:”);
Serial.print(t);
Serial.println(””);
//ST//
byte i2cAddress = 0x04; // Slave address (SingleTact), default 0x04
short data = readDataFromSensor(i2cAddress);
Serial.print(“Sensor_Data:”);
Serial.println(data);
//S8 A= 50.265mm^2 // S8 A= 176.715mm^2
// Pressure = (data/512) * 1/A = N/mm2 = (N/mm^2)*7500.63755 = mmHg
Pressure = ((data/512)/176.715)*7500.63755;
Serial.print("Pressure in mmHg: ");
Serial.println(Pressure);
File myFile = SD.open("st.txt", FILE_WRITE);
if (myFile) {
myFile.print(h);
myFile.print(",");
myFile.print(t);
myFile.print(",");
myFile.print(",");
myFile.print(",");
myFile.print(data);
myFile.print(",");
myFile.println(Pressure);
myFile.close();
} else {
Serial.print(“DATA,DATE,TIME,” + String() + “,” + String(h) + “,” + String(t) + “,” + +"," + + “,” + String(data) + “,” + String(Pressure));
Serial.println();
Serial.println("--------------------");
delay(1000); // Change this if you are getting values too quickly
short readDataFromSensor(short address)
byte i2cPacketLength = 6;//i2c packet length. Just need 6 bytes from each slave
byte outgoingI2CBuffer[3];//outgoing array buffer
byte incomingI2CBuffer[6];//incoming array buffer
outgoingI2CBuffer[0] = 0x01;//I2c read command
outgoingI2CBuffer[1] = 128;//Slave data offset
outgoingI2CBuffer[2] = i2cPacketLength;//require 6 bytes
Wire.beginTransmission(address); // transmit to device
Wire.write(outgoingI2CBuffer, 3);// send out command
byte error = Wire.endTransmission(); // stop transmitting and check slave status
if (error != 0) return -1; //if slave not exists or has error, return -1
Wire.requestFrom(address, i2cPacketLength);//require 6 bytes from slave
byte incomeCount = 0;
while (incomeCount < i2cPacketLength) // slave may send less than requested
if (Wire.available())
incomingI2CBuffer[incomeCount] = Wire.read(); // receive a byte as character
incomeCount++;
else
delayMicroseconds(10); //Wait 10us
short rawData = (incomingI2CBuffer[4] << 8) + incomingI2CBuffer[5]; //get the raw data
return rawData;
senor%20data
