I think you should check the thread for Carloop, the open-source product Particle and OBD-II ports.
OBD-II is CAN bus, which is similar to serial but is multi-drop and requires a transmitter enable and differential signaling. Details of how Carloop does this are in their github repo which you can find in that thread.
