Retained Memory Tips
You are missing what I am saying - I’m my view whether a battery is or isn’t connected - the first time the code is run - the value should be 0 - then after that point and as long as battery/power is connected - the value will be retained as its last set value.
Using the above example - with or without a battery connected the first time the code is run it is never 0. as expected it does increment from what ever value it first shows.
STARTUP(System.enableFeature(FEATURE_RETAINED_MEMORY));
retained int savedValue = 0;
 Serial.begin(9600);
Serial.printlnf(“savedValue=%d”, savedValue++);
delay(1000);
