Request: Particle endorsed Semi Automatic, Thread mode test case .ino
Would it help for me to file bugs on the github? Currently the code doesn’t work if you put everything in sequence, and after 3 weeks it seems it’s not known at HQ how to structure logic to make sure it works. By process of elimination that means it mustn’t be working, ie the code is faulty.
I’m currently testing turning off semi-automatic mode as it’s been 3 weeks and I need to ship features.
Edit: BTW back in the day we used to need semi-automatic mode to directly influence listening mode with ISR’s etc with @peekay123’s timer libraries. At the moment it seems I can get most functionality without semi-automatic and the sequential list of commands works. Hence my comment that’s actually a software bug with semi-automatic.
