@IUnknown - It seems I also am troubleshooting a similar issue but on a Boron. I’ve been documenting my steps in a separate thread. You may want to read through the entire thread but here is the latest post: Boron - Seemingly random device reset - How to best capture the reason
It seems by conditioning when to use Particle.publish() vs publishQueue.Publish() based on Particle.connected has corrected or at least greatly improved my situation. I plan on rolling out the tet to 8 additional Boron’s this evening and see how long they can stay connected.
if (Particle.connected()){
Particle.publish("Stat", jw.getBuffer(), 60, PRIVATE, WITH_ACK);
else {
publishQueue.publish("Stat", jw.getBuffer(), 60, PRIVATE, WITH_ACK);
I would be curious to learn if they same would help you and your Argons or if it’s just me/something I’m doing. I’ll continue to post my results to my original thread but will follow this thread here too. Please continue to report what you find.
