Porting the ethernet library from Arduino
@peekay123 Here’s the link to all the source files.
I compiled this locally against 0.6.1 firmware. AFAIK no more changes were made than these two lines I’ve mentioned, but I didn’t run diff against mine and the orginal files. I used the code you’ve posted on dropbox as a starter. There’s a lot of commented out Serial.print*.
