Porting SDI-12 Electron library to Boron LTE
I just PR this fork supports using SDI-12 in the Boron LTE to the open-source EnviroDIY SDI12 library. You can try it from joaquinperaza/Arduino-SDI-12
I am using the ClimaVUE atmospheric sensor without any other board running smoothly. I just plugged into the D2 of the Boron and started receiving data. I also included a script for testing in the examples folder.
Hi @joaquinperaza, I am trying to use your particle boron example in Visual Studio and am running into a few issues. It seems like some of the libraries used in the script are still Arduino libraries so am curious of how you got your script to work. Thank you for the help! Hope this is still relevant 2 years late.
@Roocow anything end up working for you?
Did you figure it out? Otherwise I have a SDI library adapted for use with B5-SoM
Hi, we switched to using the DDI interface between our Boron and CTD. Thank you for your response!
Hi, @claursen—is your SDI library for the BSoM available for testing? Thanks!
Hello supscientist,
I'll dig it out Tomorrow and share it here! Sorry for the late reply - I don't get notifications on thread replies.
European Summer holidays got in the way - see link below and note the pin definition are for our b5som implementation in the SDI12Master.h - yours may be different. I can't attach .zip's here, but here's a downloadable link: Proton Drive
If I remember correctly, we use it with the MAX487ESA+TCBX
