here it is: ![]()
Does the USB host shield library not give OTG capabilities used with a USB host shield and the Spark shield-shield?
I have found a bad connection! I will fix it and let you know the results.
@kennethlimcp We have serial output! My next objective is to make the data transmission occur over WiFi - I need to do some research on the best way to to accomplish this, options being: Spark.publish, Spark.variable, TCPServer/TCPClient, or UDP. I am not too concerned about byte limits, but I will need to push the data from the Spark Core by taking an action such as scanning a barcode (as opposed to a time-driven process), does that limit my options or should I delve into each to see which fits my needs best?
Gosh, thank you! You just saved me a ton of time!
