[Photon] Unable to flash new code
Here we go - see here https://hybris.box.com/s/y97vhjhodxrom5oqaet7lh6en90mojzc
Please let me know how to proceede.
Cheers
Sven
Hi @mdma - did you get any insights out of the dct.bin that I shared? I’d love to get the photon back alive.
Cheers
Sven
Hi there Sven, Could you please try updating to the latest 0.4.3 release.
And then we’ll take it from there!
Cheers,
mat.
just updated to 043 seems to be working!
Hi @mdma, just used dfu-util to flash with 0.4…3 - the photon now blinks white again, just like before. Please let me know what I can do.
I am working with another photon now, @mdma, but I’d love to figure out what happened to the first one. It it’s a pure hardware issue, could I get it replaced?
Hello there @hansamann. Sorry for the delay in getting back to you. Please try safe mode and let me know what happens. Thanks! :smile:
Hi @mdma, just tried it and it’s really weird. It will simply start flashing white again immediately. It flashes once per second I think, that’s it.
One thing I noticed, that I also don’t understand: I can reach teh dfu mode for example (yellow) by just holding the setup button. I should require the reset / setup both and then release reset I guess. Or my device is somehow stuck in thsi white flash mode.
The reset button itself seems to work - pressing it stops the white flashing, but releasing it will immediately start the white flashing again…
Thanks for trying that. Do you have access to a JTAG programmer?
This is a shot in the dark but I had a Core that had a bad RGB LED and showed unexpected colors. Are you seeing the range of colors (red, green, blue) or only a limited set? In other words, this could be a bit of a wild goose chase.
The rgb led seems to be good - can change to yellow dfu mode etc .
Sorry, no…
The explanation for not needing to press the reset button is that the device is continually resetting.
I think the DCT area has become corrupted before the system was able to update the bootloader to fix the corruption.
Just for our diagnostics - did you perform a factory reset at any time?
I think you may need to open a ticket with our support team to arrange return of this device.
Hi @mdma, thx for the info. I definitely tried a factory reset. I’ll contact the support team in this case. Thx a lot.
Thanks for confirming. When the DCT is corrupt, a factory reset puts the device in an endless loop, from which we can’t recover.
