Photon,Relay Shield and Nextion Touchscreen Based Aquaponics/Indoor Greenhouse
I2C is a bus meant to communicate with multiple devices via these two pins.
The easiest is if your sensors allow to set individual bus addresses, but if not, you might still be able to have multiple sensors of the same kind if you can power them mutually exclusive.
You might also like to look at this thread
