Photon randomly disconnects from the Particle Cloud
What Device OS are you on? This might be part of a bug that may have been fixed in 6.2.1. I've not thoroughly tested it - but I had been using 5.8.0 and it was mostly stable for this specific issue. It also seems to happen when there are multiple wifi APs with the same SSID, not sure if that's your case at home.
