@tcb2 Yep, confirmed working
SUCCESS! Thanks for posting the sensor model. I am using the Parallax 28015, which does not have distinct trigger and echo pins, but rather a single SIG pin. When you connect the echo and trigger pins to the SIG pin simultaneously, the PulseIn times out, perhaps because the photon-to-sensor pulse or sensor-to-photon data is absorbed by the trigger pin. Whatever the case, the solution is to use a single pin for trigger and echo, similar to the Arduino code, by defining the pin as output for trigger and then input for PulseIn.
#define pingPin D0
pinMode(pingPin, OUTPUT);
digitalWriteFast(pingPin, LOW);
delay(50);
Serial.begin(115200);
uint32_t duration, inches, cm;
digitalWriteFast(pingPin, HIGH);
delayMicroseconds(10);
pinMode(pingPin, INPUT);
duration = pulseIn(pingPin, HIGH);
inches = microsecondsToInches(duration);
cm = microsecondsToCentimeters(duration);
Serial.print(inches);
Serial.print("in, ");
// Serial.print(cm);
// Serial.print("cm");
// Serial.println();
Serial.print(duration);
Serial.println("us");
delay (500);
uint32_t microsecondsToInches(uint32_t microseconds)
// According to Parallax's datasheet for the PING))), there are
// 73.746 microseconds per inch (i.e. sound travels at 1130 feet per
// second). This gives the distance travelled by the ping, outbound
// and return, so we divide by 2 to get the distance of the obstacle.
// See: http://www.parallax.com/dl/docs/prod/acc/28015-PING-v1.3.pdf
return microseconds / 74 / 2;
uint32_t microsecondsToCentimeters(uint32_t microseconds)
// The speed of sound is 340 m/s or 29 microseconds per centimeter.
// The ping travels out and back, so to find the distance of the
// object we take half of the distance travelled.
return microseconds / 29 / 2;
I can confirm that the above code also works with the MaxBotix LV-Maxsonar-EZ when connected to the PW pin. Kudos to BDub for getting PulseIn up and running!
