Particle Photon multi blink sample using threads
Hello,
Here are my questions more analytically:
However you mention C++11 threading primitives, which I have no idea what it is!
I will read some documentation. I hope it is an RTOS!
I will get back to you if I have more questions.
Thanks for the answer!
Vasileios.
I was just wondering: Is it possible to forward another parameter to such a separate thread once it is already running?
Trying to use a separate thread for updating an oled display:
    #include <Adafruit_SSD1306.h>
    #include "application.h"
    //https://community.particle.io/t/particle-photon-multi-blink-sample-using-threads/16214
    // LED Param, defines pin and delay between blinks
    #define OLED_RESET D4
    Adafruit_SSD1306 oled(OLED_RESET);
    typedef struct {
        char *title;
        char *line1;
        char *line2;
        char *line3;
        char *line4;
        char *line5;
        char *line6;
    } SCREEN_PARAM;
    //Variables (lines on oled display)
    char *TITLE = "TITLE";
    char *L1 = "L1";
    char *L2 = "L2";
    char *L3 = "L3";
    char *L4 = "L4";
    char *L5 = "L5";
    char *L6 = "L6";
    // Defines thread parameters
    SCREEN_PARAM screenParams[3] = {
        {TITLE, L1, L2, L3, L4, L5, L6}
    Thread* displayThread;
    os_thread_return_t ledBlink(void* param){
        SCREEN_PARAM *p = (SCREEN_PARAM*)param;
        // Start never ending loop
        for(;;) {
             oled.clearDisplay();
             oled.setTextSize(2);
             oled.setTextColor(WHITE);
             oled.setCursor(0,0);
             oled.println(p->title);
             oled.setTextSize(1);
             oled.println(p->line1);
             oled.println(p->line2);
             oled.println(p->line3);
             oled.println(p->line4);
             oled.println(p->line5);
             oled.println(p->line6);
             oled.display();
        oled.begin(SSD1306_SWITCHCAPVCC, 0x3C);  // initialize with the I2C addr 0x3D (for the 128x64)
        Serial.begin(115200);
        // Start seperate thread for display
        displayThread = new Thread("sample", ledBlink, &screenParams[0]);
    TITLE = "TEST1";
    delay(2000);
    TITLE = "TEST2";
    delay(2000);
EDIT: FOUND THE SOLUTION.
    // ClickButton Library for button inputs
    #include <clickButton.h>
    // Display Lobrary for I2C/SPI Oled display
    /* ============== MAIN =====================*/
     //Use I2C with OLED RESET pin on D4 (not used I guess)
     //Definition of the button
    const int buttonPin1 = 5;
    ClickButton button1(buttonPin1, LOW, CLICKBTN_PULLUP);
    //Initilisiation running mode
    int mode = 0;
    //Button results
    int function = 0;
    char *L1 = "L1";
    char *L2 = "L2";
    char *L3 = "L3";
    char *L4 = "L4";
    char *L5 = "L5";
    char *L6 = "L6";
    //Definition for seperate display thread
    os_thread_return_t ledBlink(void*) {
        for(;;) {
             oled.println(TITLE);
             oled.println(L1);
             oled.println(L2);
             oled.println(L3);
             oled.println(L4);
             oled.println(L5);
             oled.println(L6);
             oled.display();
             delay(2000);
             //just a test
             oled.println("TITLE");
             oled.println("L1");
             oled.println("L2");
             oled.println("L3");
             oled.println("L4");
             oled.println("L5");
             oled.println("L6");
             oled.display();
             delay(2000);
        //Initialisation of oled display
        //Configuration of inout buttin
        pinMode(D5, INPUT_PULLUP);
        //Setup button timers (all in milliseconds / ms)
        button1.debounceTime   = 20;   // Debounce timer in ms
        button1.multiclickTime = 250;  // Time limit for multi clicks
        button1.longClickTime  = 1000; // time until "held-down clicks" register
        //Start seperate display thread
        displayThread = new Thread("sample", ledBlink);
    //Starting general loop
      //Update button state
      button1.Update();
      //Save click codes in LEDfunction, as click codes are reset at next Update()
      if(button1.clicks != 0) function = button1.clicks;
      //runmode = ready (0)
      if(mode == 0) {
        TITLE = "EINLEGEN!";
        L1 = "";
        L2 = "PDM Presnets:";
        L3 = "Ostersaufen 2018";
        L4 = "Haesli-Choepfer 2.0";
        L5 = "";
        L6 = "";
        //oled.clearDisplay();
        //oled.setTextSize(2);
        //oled.setTextColor(WHITE);
        //oled.setCursor(0,0);
        //oled.println("EINLEGEN!");
        //oled.setTextSize(1);
        //oled.println();
        //oled.println("1. Draht anheben");
        //oled.println("2. Hase einlegen");
        //oled.println("3. Start Knopf (1s)");
        //oled.display();
        //delay(2000);
      //runmode = finished (1)
      if(mode == 1) {
        TITLE = "KOPF AB!";
        L1 = "";
        L2 = "Kampfhase und Kopf";
        L3 = "entfernen!";
        L4 = "";
        L5 = "Kindersicherung nicht";
        L6 = "vergessen!";
        //oled.println("KOPF AB!");
        //oled.println();
        //oled.println("Kindersicherung nicht");
        //oled.println("vergessen!");
        //oled.display();
        //delay(2000);
      //mode = burning (2)
      if(mode == 2) {
        TITLE = "PDM Presnets:";
        L1 = "";
        L2 = "SHORT PRESS";
        L3 = "BURNING MODE";
        L4 = "";
        L5 = "";
        L6 = "";
      //short end-stop input
      if(function == 1) mode = 2;
      //long end-stop input
      if(function == -1) mode = 1;
      //if(function == 2) Serial.println("DOUBLE click");
      //if(function == 3) Serial.println("TRIPLE click");
      //if(function == -2) Serial.println("DOUBLE LONG click");
      //if(function == -3) Serial.println("TRIPLE LONG click");
      function = 0;
      delay(5);
Threads can access global variables.
To expand on @ScruffR reply, “Threads can access global variables” … and they should be atomic
For those following this thread, @rickkas7 created a sweet, descriptive “Particle threads tutorial” doc in April 2018. Well written with good examples that one can reference and follow … https://github.com/rickkas7/particle-threads
