Particle drawing 180mA from battery while in deep sleep mode
That code won't work properly. It's like example 3. Since you're in SEMI_AUTOMATIC mode (also happens for MANUAL), the cellular modem is not turned on when the Electron resets. Thus is can't be put to sleep properly.
If you modify it so it's like example 4 it probably will go to sleep properly, though the warning about burden voltage on your meter still applies.
