Device OS 1.4.1-rc.1 Release Candidate is out on the Web IDE for (Core/Photon/P1/Electron/Argon/Boron/Xenon/A SoM/B SoM/X SoM)
released on October 1st, 2019
:white_check_mark: This 1.4.1-rc.1 Release Candidate will be defaulted to 1.4.1 on October 14th, 2019 unless there are regressions found that require further patches. :pencil: Testing on your applications is encouraged and appreciated, thank you! :person_bowing:
Note: This is a Release Candidate (RC) and is not intended for production yet. We've tested this RC to the best of our ability and we want to know what you think now! Please understand that some care and attention is necessary when testing this RC, and be sure to upgrade to the final release when it's available. This RC will not be available by default. To use you must select the version dropdown from the devices drawer. Downgrading back to the current release info is at the bottom of this post.
  4. Then update to 1.2.1 (if the current version is less than that)
  5. Then update to 1.4.1-rc.1
  • You may update to 1.4.1-rc.1 directly first, flash the system firmware (attached above) in order 1,2(,3) to the device using particle flash --usb <system-part.bin>. See the next note about the bootloader if you are offline!
Note: P1/Photon Bootloader
The Cloud will automatically update the bootloader on P1/Photon devices if your device is online. If your device does not connect to the cloud and it is offline, you should flash the bootloader to the device using particle flash --serial <bootloader.bin>. This should be done after upgrading system firmware. The Electron bootloader is applied automatically from it's own system parts.
Note: Argon/Boron/Xenon/Argon-SoM/Boron-SoM/Xenon-SoM Bootloader
If your device is offline, the bootloader must be manually updated using particle flash --serial <bootloader.bin>. This can be done before or after upgrading system firmware.
Note: Argon/Boron/Xenon/Argon-SoM/Boron-SoM/Xenon-SoM SoftDevice
1.4.1-rc.1
Note: If your Gen 2 Photon/P1 or Gen 3 device does not have a Cloud connection, it is recommended to update system firmware, and then the bootloader via CLI with particle flash --serial bootloader.bin (bootloaders found in Github release). Electron bootloaders are still contained in system firmware and will update automatically as needed.
This release contains v500 bootloaders.
SoftDevice update
Prerequisites
particle-cli version 1.47.0.
Upgrading OTA
  1. Upgrade to 1.4.1-rc.1
  2. Manually flash 1.4.1-rc.1 bootloader: particle flash <deviceId> boron-bootloader@1.4.1-rc.1.bin
  3. Flash SoftDevice: particle flash <deviceId> boron-softdevice@1.4.1-rc.1.bin
Upgrading using YModem
  3. Manually flash 1.4.1-rc.1 bootloader: particle flash --serial boron-bootloader@1.4.1-rc.1.bin
  4. Flash SoftDevice: particle flash --serial boron-softdevice@1.4.1-rc.1.bin
  1. Upgrade Device OS to 1.4.1-rc.1
  2. Update the bootloader to 1.4.1-rc.1 with the OTA or YModem process above
  4. Flash the SoftDevice: particle flash --usb boron-softdevice@1.4.1-rc.1.bin
FEATURES
  • [Gen 2] Adds support for serial number, NCP type and mobile secret in STM32F2 OTP area #1927 #1931
ENHANCEMENTS
  • [Electron, Boron] Increase the PMIC input current limit from 900mA to 1500mA and limit charging current to 896mA to allow 2G/3G devices to function when powered by sufficient power supply through VIN without the battery #1921
  • DTLS handshake timeout increased to 24 seconds to allow 3 retransmission attempts #1914
BUGFIXES
  • [Electron] Fixes RSSI failing due to Power Saving mode active #1917 #1892
  • [Gen 3] Fixes memory leak when scanning for BLE devices #1929 #1926
  • [Gen 3] Fixes reporting of discovered BLE peer characteristic descriptors #1916
  • [Gen 3] Fixes BleCharacteristic::setValue() with default BLeTxRxType argument (BleTxRxType::AUTO) for characteristics with WRITE property #1915 #1913 #1924
INTERNAL
  • [ci] Buildpack builder updated to unreleased branch feature/buildpack-runnable-without-travis to move buildpack builds off of Travis
  • [docs] Adds Artifact Versioning and Tagging (1.0.0) artifacts.md #1703
System Binaries (all devices)
https://github.com/particle-iot/device-os/releases/download/v1.4.1-rc.1/particle_device-os@1.4.1-rc.1.zip
Programming and Debugging
