Device OS 1.1.1 Default Release is out on the Web IDE for Core/Photon/P1/Electron/Argon/Boron/Xenon/A SoM/B SoM/A SoM
released on production servers June 28th, 2019
Note: This is a Release and may be used for production. Any known issues are likely slated for a future version, (check Github issues). It is available by default for all devices. To use, select the 1.1.1 version dropdown from the devices drawer.
Note: If you have previously last used one of the prerelease versions of 1.1.1-rc.x on a device, please re-flash it with 1.1.1.
  4. Then update to 1.1.1
Note: DFU over USB on Photon/P1/Electron/Argon/Boron/Xenon/A SoM/B SoM/A SoM (sequence not required)
  • You may update to 1.1.1 directly first, flash the system firmware (attached above) in order 1,2(,3) to the device using particle flash --usb <system-part.bin>. See the next note about the bootloader if you are offline!
Note: P1/Photon Bootloader
The Cloud will automatically update the bootloader on P1/Photon devices if your device is online. If your device does not connect to the cloud and it is offline, you should flash the bootloader to the device using particle flash --serial <bootloader.bin>. This should be done after upgrading system firmware. The Electron bootloader is applied automatically from it's own system parts.
Note: Downgrading [Photon/P1/Electron] OTA or YModem transfer:
1.1.1
BUGFIXES
  • [Electron/LTE] disables all eDRX AcT types [ch32051] #1762
  • [LTE] cellular fixes #1824
Release v1.1.1 (Core/Photon/P1/Electron/Argon/Boron/Xenon/A SoM/B SoM/A SoM) · particle-iot/device-os · GitHub
Programming and Debugging
