Device OS 4.0.1 LTS is available in the Web IDE, Particle CLI and Workbench for (Argon/Boron/B SoM/B5 SoM/Tracker/E SoM X).
Released on November 14th, 2022
Note: This is a Release and may be used for production. This is the second Release in the Device OS release 4.x line (LTS) with critical bugfixes and backports from 5.x release line
Device OS v3.1.x and further releases bring support for 256KB application binaries to all Gen 3 platforms (at that time: Argon, Boron, B SoM, B5 SoM, Tracker). A few important aspects of this change:
- If using standalone Particle CLI installation, make sure it's updated to >= 2.12.0 version, which includes support for 256KB applications.
4.0.1
BUGFIXES
- [wiring] ApplicationWatchdog: fixes potential 2x timeout required to fire #2536
- [gen3]Fix BLE control request channel sending malformed packets #2538
- Fix issue with platform_ncp_get_info(0) for quectel platforms #2532
- Secures DCT initialization from getting interrupted between creating DCT file and filling it with 0xff to default state #2530
- [Boron / B SoM] R410 PPP crash in network phase workaround #2571
- [Cellular] R410 initialization SIM failure workaround #2573
INTERNAL
- Use new
prtclcompile/clean commands for internal CI builds #2543 - Increase timeouts for internal CI builds on windows #2545
- HAL wiring api calls to access exflash read/write functions for OTP flash page #2540
- [hal] wifi: add generic 'world' country code as not every country code is exposed through API #2539
System Binaries (all devices)
https://github.com/particle-iot/device-os/releases/download/v4.0.1/particle_device-os@4.0.1.zip
Programming and Debugging
Branches
release/stable and master branches have been updated to point to v4.0.1 tag.
