I understand. Thank you for pointing this out. I will add that to the places I look when using a new library.
Chip
Chip
Quick question. In your examples, you have the class definition in the main execution file. I was wondering, would it be possible to refactor the implementation using a Singleton approach? That way, the main execution file could be abstracted from the storage technology. I tried to make this work with the code generator you built for Singletons:
I believe this is important as the current implementation will only work if your program is in a single monolithic file. I am working to see if I can make a class out of this that could be called by more than one file. I will share my progress here and if anyone is good at the concepts of Singletons and Classes and could give me any advice, it would be appreciated. If I / we figure it out, I will share the result here:
Thanks, Chip
So, with @jgskarda 's help, we now have the StorageHelperRK wrapped up in a Singleton approach. Would greatly appreciate anyone’s opinions on how to do this better but, by using the library this way, You can move all the storage-technology-specific references from the main CPP file and share access to the persistent storage across multiple modules that make up a project. Here is what the main file looks like now:
#include "Particle.h"
#include "MyPersistentData.h"
#include "Another_Module.h"
SYSTEM_THREAD(ENABLED);
SYSTEM_MODE(MANUAL);
// Optional: Enable to make it easier to see debug USB serial messages at startup
waitFor(Serial.isConnected, 10000);
data.setup(); // loading is part of setup in this approach
data.logData("after loading");
static unsigned long lastCheck = 0;
if (millis() - lastCheck >= 10000) {
lastCheck = millis();
data.setValue_test1(data.getValue_test1() + 1); // Change values to see if these are reflected
data.setValue_test2(!data.getValue_test2());
data.setValue_test3(data.getValue_test3() - 0.1);
data.setValue_test4("testing!");
data.logData("after update");
testStorageAccess(); // Show we can access storage from another module
data.loop();
And here are the files that make StorageHelper into a Class:
/* __MyPersistentData_H */
* @file MyPersistentData.h
* @author JGSkarda -
* @brief All functions that are used to handle persistent data
* @details Make library into a class that can be shared across modules in a project
* @date 9/12/22
* Version History:
* 0.1 - Initial realease - Works
//Include a standard header guard
#ifndef __MyPersistentData_H
#define __MyPersistentData_H
//Include standard header files from libraries:
#include <Particle.h>
#include <MB85RC256V-FRAM-RK.h>
#include <StorageHelperRK.h>
//Include other application specific header files
// #include (no other header files required from other singleton classes)
//Define external class instances. These are typically declared public in the main .CPP. I wonder if we can only declare it here?
extern MB85RC256V fram;
//Macros(#define) to swap out during pre-processing (use sparingly). This is typically used outside of this .H and .CPP file within the main .CPP file or other .CPP files that reference this header file.
// This way you can do "data.setup()" instead of "MyPersistentData::instance().setup()" as an example
#define data MyPersistentData::instance()
* This class is a singleton; you do not create one as a global, on the stack, or with new.
* From global application setup you must call:
* MyPersistentData::instance().setup();
* From global application loop you must call:
* MyPersistentData::instance().loop();
class MyPersistentData : public StorageHelperRK::PersistentDataFRAM {
public:
* @brief Gets the singleton instance of this class, allocating it if necessary
* Use MyPersistentData::instance() to instantiate the singleton.
static MyPersistentData &instance();
* @brief Perform setup operations; call this from global application setup()
* You typically use MyPersistentData::instance().setup();
void setup();
* @brief Perform application loop operations; call this from global application loop()
* You typically use MyPersistentData::instance().loop();
void loop();
class MyData {
public:
// This structure must always begin with the header (16 bytes)
StorageHelperRK::PersistentDataBase::SavedDataHeader header;
// Your fields go here. Once you've added a field you cannot add fields
// (except at the end), insert fields, remove fields, change size of a field.
// Doing so will cause the data to be corrupted!
// You may want to keep a version number in your data.
int test1;
bool test2;
double test3;
char test4[10];
// OK to add more fields here
MyData myData;
* @brief Get the value of....
* You typically use MyPersistentData2::instance().getValue_test1();
int getValue_test1() const;
* @brief Set the value of....
* You typically use MyPersistentData2::instance().setValue_test1;
void setValue_test1(int value);
* You typically use MyPersistentData2::instance().getValue_test2();
bool getValue_test2() const;
* You typically use MyPersistentData2::instance().setValue_test2;
void setValue_test2(bool value);
* You typically use MyPersistentData2::instance().getValue_test3();
double getValue_test3() const;
* You typically use MyPersistentData2::instance().setValue_test3;
void setValue_test3(double value);
* You typically use MyPersistentData2::instance().getValue_test4();
String getValue_test4() const;
* You typically use MyPersistentData2::instance().setValue_test4;
bool setValue_test4(const char *str);
* @brief Log the data
* You typically use MyPersistentData2::instance().logData;
void logData(const char *msg);
//Members here are internal only and therefore protected
protected:
* @brief The constructor is protected because the class is a singleton
MyPersistentData();
* @brief The destructor is protected because the class is a singleton and cannot be deleted
virtual ~MyPersistentData();
* This class is a singleton and cannot be copied
MyPersistentData(const MyPersistentData&) = delete;
MyPersistentData& operator=(const MyPersistentData&) = delete;
* @brief Singleton instance of this class
* The object pointer to this class is stored here. It's NULL at system boot.
static MyPersistentData *_instance;
//Since these variables are only used internally - They can be private.
static const uint32_t DATA_MAGIC = 0x20a99e73;
static const uint16_t DATA_VERSION = 1;
#endif /* __MyPersistentData_H */
and here is the CPP file
MB85RC256V fram(Wire, 0);
MyPersistentData *MyPersistentData::_instance;
// [static]
MyPersistentData &MyPersistentData::instance() {
if (!_instance) {
_instance = new MyPersistentData();
return *_instance;
MyPersistentData::MyPersistentData() : StorageHelperRK::PersistentDataFRAM(::fram, 0, &myData.header, sizeof(MyData), DATA_MAGIC, DATA_VERSION) {
MyPersistentData::~MyPersistentData() {
void MyPersistentData::setup() {
fram.begin();
data.load();
void MyPersistentData::loop() {
data.flush(false);
int MyPersistentData::getValue_test1() const
return getValue<int>(offsetof(MyData, test1));
void MyPersistentData::setValue_test1(int value) {
setValue<int>(offsetof(MyData, test1), value);
bool MyPersistentData::getValue_test2() const {
return getValue<bool>(offsetof(MyData, test2));
void MyPersistentData::setValue_test2(bool value) {
setValue<bool>(offsetof(MyData, test2), value);
double MyPersistentData::getValue_test3() const {
return getValue<double>(offsetof(MyData, test3));
void MyPersistentData::setValue_test3(double value) {
setValue<double>(offsetof(MyData, test3), value);
String MyPersistentData::getValue_test4() const {
String result;
getValueString(offsetof(MyData, test4), sizeof(MyData::test4), result);
return result;
bool MyPersistentData::setValue_test4(const char *str) {
return setValueString(offsetof(MyData, test4), sizeof(MyData::test4), str);
void MyPersistentData::logData(const char *msg) {
Log.info("%s: %d, %d, %lf, %s", msg, myData.test1, (int)myData.test2, myData.test3, myData.test4);
To test whether we should share storage access with another file, I make this simple module that would access storage and was called from the main file
#ifndef ANOTHER_MODULE_H
#define ANOTHER_MODULE_H
void testStorageAccess();
#endif
and the test function
void testStorageAccess() {
data.logData("From another module:");
Again, @jgskarda and I are just getting started on this approach. Any comments / suggestions would be appreciated. I would be especially interested if @rickkas7 would agree this is a reasonable use of the StorageHelperRK library.
Thanks, Chip
Yes, that is a good way to make your settings object available across multiple modules.
you guys rock!
