Not to hijack an old thread, but I started putting together something nearly identical using SmartThings. Just changing out the microcontroller for a Spark would be a piece of cake.
Hey guys. Although I donāt have the fancy neopixels, I still wanted a sunrise clock. Iāve now just made an array of RGB values that the code will walk through as soon as the relevant code is activated, based on the TimeAlarms library. I got the color values by using a web gradient maker, converting the hex values to rgb, and stuffing them in an array. This is by no means great, and Iām not sure if it resembles an actual sunrise, but as a proof-of-concept, it looks okay. Iāve used 300 values, to go over a period of 30mins. 1 every 6 seconds. The time can be changed by using the slider in the complementary webpage. Iām not sure if itās possible, but I intend on using the FRAM/SD shield by @kennethlimcp to increase the number of values, making for a smoother transition.
Also, has anybody considered that pairing your RGB strips to this thing might be really nifty: https://www.kickstarter.com/projects/hello/sense-know-more-sleep-better?ref=home_popular It has a sleeping analyser, and will start to gradually wake you up as soon as it senses that youāre getting awake naturally. They say theyāll release an API which can be used to do whatever with. If you could hook this up to a sunrise lighting, your mornings might become a whole lot smoother. Added bonus: that clock thingy contains a few neat sensors, so yeah: collect ALL the data! You can make that thing handle all the āregularā alarm stuff, and make it do things by pairing it with your Spark, which can then drive things like RGB strips, heaters, and what-eversā¦
Anyhow, this is the code I currently use for the sunrise stuff, if anybodyās interested:
Spark:
#include "TimeAlarms/TimeAlarms.h"
#define ledPin D7
#define redPin A0
#define greenPin A1
#define bluePin A5
int ledState = LOW; // ledState used to set the LED
long previousMillis = 0; // will store last time LED was updated
int r = 0;
int g = 0;
int b = 0;
char pubstring[64];
int redList[] = { 0,8,17,26,35,43,52,61,70,79,87,96,105,114,123,131,140,149,158,167,175,184,193,202,211,219,228,237,246,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,254,253,253,252,252,251,250,250,249,249,248,247,247,246,246,245,245,244,243,243,242,242,241,240,240,239,239,238,237,237,236,236,235,235,234,233,233,232,232,231,230,230,229,229,228,228,227,226,226,225,225,224,223,223,222,222,221,220,220,219,219,218,218,217,216,216,215,215,214,213,213,212,212,211,211,210,209,209,208,208,207,206,206,205,205,204,203,203,202,202,201,201,200,199,199,198,198,197,196,196,195,195,194,193,193,192,192,191,191,190,189,189,188,188,187,186,186,185,185,184,184,183,182,182,181,181,180,179,179,178,178,177,176,176,175,175,174,174,173,172,172,171,171,170,169,169,168,168,167,167,166,165,165,164,164,163,162,162,161,161,160,159,159,158,158,157,157,156,155,155,154,154,153,152,152,151,151,150,150,149,148,147,146,145,144,142,141,140,139,138,137,136,135,134,133,132,131,130,129,128
int greenList[] = { 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,2,4,6,8,10,13,15,17,19,21,23,26,28,30,32,34,36,39,41,43,45,47,49,52,54,56,58,60,62,65,67,69,71,73,75,78,80,82,84,86,88,91,93,95,97,99,101,104,106,108,110,112,114,117,119,121,123,125,128,128,130,132,135,137,140,142,145,147,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,149,148,147,146,145,144,142,141,140,139,138,137,136,135,134,133,132,131,130,129,128
int blueList[] = { 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,1,2,3,5,6,7,9,10,11,12,14,15,16,18,19,20,22,23,24,25,27,28,29,31,32,33,34,36,37,38,40,41,42,44,45,46,47,49,50,51,53,54,55,57,58,59,60,62,63,64,66,67,68,69,71,72,73,75,76,77,79,80,81,82,84,85,86,88,89,90,92,93,94,95,97,98,99,101,102,103,104,106,107,108,110,111,112,114,115,116,117,119,120,121,123,124,125,127,128,129,130,132,133,134,136,137,138,139,141,142,143,145,146,147,149,150,151,152,154,155,156,158,159,160,162,163,164,165,167,168,169,171,172,173,174,176,177,178,180,181,182,184,185,186,187,189,190,191,193,194,195,197,198,199,200,202,203,204,206,207,208,209,211,212,213,215,216,217,219,220,221,222,224,225,226,228,229,230,232,233,234,235,236,237,238,240,241,242,243,244,245,246,247,248,249,250,251,252,253,255
int x = 0;
int duration = 6000;
//300 color values times "duration" milliseconds is the time the sunrise goes for.
//The sunset is set to 1/6 of that time. At 6000ms this will take 30mins for a sunrise,
//and 5mins for a sunset. This value can be changed by the slider on the webpage,
//from 0 to 6000.
Time.zone(+2); //Amsterdam, Paris, stuff like that...
// create the alarms
Alarm.alarmRepeat(8,15,0, MorningAlarm); // 8:15am every day
Alarm.alarmRepeat(9,15,0, MorningOffAlarm); // 9:15pm every day
pinMode(ledPin, OUTPUT);
pinMode(redPin, OUTPUT);
pinMode(greenPin, OUTPUT);
pinMode(bluePin, OUTPUT);
RGB.control(true);
RGB.color(255,0,0);
myDelay(200);
RGB.color(0,0,0);
myDelay(200);
RGB.color(0,0,255);
myDelay(200);
pubcolor();
Spark.function("params", handleParams);
digitalClockDisplay();
Alarm.delay(1000); // wait one second between clock display
int handleParams(String command)
int p = 0;
while (p<(int)command.length()) {
int i = command.indexOf(',',p);
if (i<0) i = command.length();
int j = command.indexOf('=',p);
if (j<0) break;
String key = command.substring(p,j);
String value = command.substring(j+1,i);
int val = value.toInt();
if (key=="r"){
r = val;
Serial.println('Set red value');
else if (key=="g"){
g = val;
Serial.println('Set green value');
else if (key=="b"){
b = val;
Serial.println('Set blue value');
else if (key == "GetColor"){
//Just doing this to get the colors published.
else if (key == "duration"){
//change the duration of the sunrise/sunset.
duration = val;
else if (key == "sunrise"){
//execute sunrise.
sunrise();
else if (key == "sunset"){
//execute sunset.
sunset();
p = i+1;
//change colors to said values.
color(r, g, b);
//publish colors.
pubcolor();
// duration is delay time in milliseconds
void myDelay(unsigned long duration)
unsigned long start = millis();
while (millis() - start <= duration)
blink(100); // blink the LED inside the while loop
// interval is the time that the LED is on and off
void blink(long interval)
if (millis() - previousMillis > interval)
// save the last time you blinked the LED
previousMillis = millis();
// if the LED is off turn it on and vice versa:
if (ledState == LOW)
ledState = HIGH;
else
ledState = LOW;
digitalWrite(ledPin, ledState);
//set the colors all at once, usefull as shorthand.
void color (unsigned char r, unsigned char g, unsigned char b){
analogWrite(redPin, r);
analogWrite(greenPin, g);
analogWrite(bluePin, b);
RGB.color(r, g, b);
//Convert color values to JSON string and publish them.
void pubcolor(){
sprintf(pubstring,"{\"r\": %u, \"g\": %u, \"b\": %u}",r,g,b);
Spark.publish("color_values",pubstring);
Serial.println(String(pubstring));
//Sunrise function. Walks through the arrays.
void sunrise(){
for (x = 0; x < 300; x++){
r = redList[x];
g = greenList[x];
b = blueList[x];
myDelay(duration);
color(r, g, b);
//Sunset function. Walks through the arrays.
void sunset(){
for (x = 0; x < 301; x++){
r = redList[300-x];
g = greenList[300-x];
b = blueList[300-x];
myDelay(duration/6);
color(r, g, b);
//======================== ALARMS ===========================
// functions to be called when an alarm triggers:
void MorningAlarm(){
Serial.println("Alarm: - turn lights on");
RGB.color(255,0,0);
myDelay(200);
RGB.color(0,0,0);
myDelay(200);
RGB.color(0,0,255);
myDelay(200);
sunrise();
void MorningOffAlarm(){
Serial.println("Alarm: - turn lights off");
r = 0;
g = 0;
b = 0;
color(r, g, b);
RGB.color(r,g,b);
void digitalClockDisplay()
// digital clock display of the time
Serial.print(Time.hour());
printDigits(Time.minute());
printDigits(Time.second());
Serial.println();
void printDigits(int digits)
Serial.print(":");
if(digits < 10)
Serial.print('0');
Serial.print(digits);
HTML code:
<!DOCTYPE HTML>
<html>
<meta name="viewport" content="width=device-width, initial-scale=1, user-scalable=no, minimal-ui">
<meta name="apple-mobile-web-app-capable" content="yes" />
<meta name="apple-mobile-web-app-status-bar-style" content="black-translucent" />
<script src="http://code.jquery.com/jquery-1.10.2.min.js"></script>
<script src="http://code.jquery.com/mobile/1.4.2/jquery.mobile-1.4.2.min.js"></script>
<link rel="stylesheet" href="http://code.jquery.com/mobile/1.4.2/jquery.mobile-1.4.2.min.css">
<script type="text/javascript">
var deviceID = " DEVICE ID HERE ";
var accessToken = " ACCESTOKEN HERE ";
var baseURL = "https://api.spark.io/v1/devices/";
var r = 0;
var g = 0;
var b = 0;
var duration;
var Colors;
var eventSource = new EventSource(baseURL + deviceID + "/events/?access_token=" + accessToken);
var requestURL = baseURL + deviceID + "/" + "GetColor" + "/?access_token=" + accessToken;
alert = function() {}; /////////////// comment this function by adding two '//' if you would like to debug. you will see alerts in your browser at almost every step. This makes it easier to see what your code is doing.
$(document).ready(function(){
alert('DOM loaded, I\'m gonna do stuff...');
$("#Red ").on( "slidestop", function( event, ui ) {
r = document.getElementById('Red').value;
Colors = document.getElementById('Red').name + r.toString();
doMethod("params", Colors);
$("#Green").on( "slidestop", function( event, ui ) {
g = document.getElementById('Green').value;
Colors = document.getElementById('Green').name + g.toString();
$("#Blue").on( "slidestop", function( event, ui ) {
b = document.getElementById('Blue').value;
Colors = document.getElementById('Blue').name + b.toString();
$("#duration").on( "slidestop", function( event, ui ) {
duration = document.getElementById('duration').value
para = "duration=" + duration.toString();
alert(para);
doMethod("params", para);
$("#off").on( "click", function( event, ui ) {
alert('off');
r = 0;
g = 0;
b = 0;
multiple = "r=" + r.toString() + ",g=" + g.toString() + ",b=" + b.toString();
alert(multiple);
doMethod("params", multiple);
$("#sunrise").on( "click", function( event, ui ) {
alert("sunrise");
doMethod("params", "sunrise=0");
$("#sunset").on( "click", function( event, ui ) {
alert("sunset");
doMethod("params", "sunset=0");
eventSource.addEventListener('color_values', function(e) {
alert('Looks like I just received a SSE...');
var rawData = JSON.parse(e.data);
var parsedData = JSON.parse(rawData.data);
color_display.innerHTML = "(" + parsedData.r + "," + parsedData.g + "," + parsedData.b + ")";
if (document.getElementById('Red').value != parsedData.r || document.getElementById('Green').value != parsedData.g || document.getElementById('Blue').value != parsedData.b){
alert('Updating stuff.');
r = parsedData.r;
g = parsedData.g;
b = parsedData.b;
updateSliders();
else {
alert('It\'s the same...');
}, false);
$(window).load(function() {
alert('Window loaded, going to execute doMethod for initial request');
doMethod("params","GetColor=0");
function updateSliders(){
alert('Going to update sliders RIGHT NOW.');
$('#Red').val(r);
$('#Green').val(g);
$('#Blue').val(b);
$('#Red, #Green, #Blue').slider('refresh');
alert('Sliders updated!');
function doMethod(method, data) {
var url = baseURL + deviceID + "/" + method;
$.ajax({
type: "POST",
url: url,
data: {
access_token: accessToken,
args: data
dataType: "json"
</script>
<body>
<div data-role="page" id="pageone">
<div data-role="content">
Red: <input type="range" name="r=" id="Red" min="0" max="255" step="1" data-highlight="true" value="0" >
Green: <input type="range" name="g=" id="Green" min="0" max="255" step="1" data-highlight="true" value="0" >
Blue: <input type="range" name="b=" id="Blue" min="0" max="255" step="1" data-highlight="true" value="0" >
Current RGB value: <span id="color_display"></span>
<br /><br />
duration (in ms): <input type="range" name="duration" id="duration" min="0" max="6000" step="10" data-highlight="true" value="6000" >
<input type="button" value="Off" id="off">
<input type="button" value="Sunrise" id="sunrise">
<input type="button" value="Sunset" id="sunset">
</div>
</div>
</body>
</html>
Iād suggest running the HTML code with the debugging enabled if youād like to get a better idea what path the code follows. Itās by no means great coding, far from it. But for me it works (for now).
Any and all suggestions are highly welcome, and sincerely appreciated!
@scsc_tech, Nice project!
@Moors7 That is awesome. Iāve finally finished moving and got to working on my projects again. Iām using a modified version of your code to control the light around my room and living room, but I havenāt figured out how to make one webpage control multiple Cores. Any suggestions? Java isnāt my strong suitā¦at all!
Great to hear my code is somewhat useful to someone. I havenāt got any experience with Java either, just what I picked up playing around with my Core. Itās one big learning experience, which has been great so far!
Having said that, I looked around Google a bit, and thought the best option here might be a Radio selector. Searching a bit further, I found a JSFiddle which I adapted to work with āourā code. Try this http://jsfiddle.net/k50vtwja/ Copy the code to the corresponding parts in the original code, edit the āvaluesā to the corresponding Cores, and you should be good to go. You can comment out the alerts, those were just for testing.
Let me know if it works, and good luck!
