@bko and using the values in the arithmetic expression always returns 0:
_resultat = (_resultat/2047)*(2.048/_PGA)*(180/33);
You’ll have to forgive my ignorance, I’ve never really worked with floating point or decimals numbers in code before
Hi @joearkay
How is _resultat declared? Also as long? That would need to be changed as well but since the same variable is used for reading other things in the code above, a new variable for the float/double value would be the best thing.
@bko _resultat is a float and _PGA is uint8_t. Would it be a good idea to change _PGA to float as well?
This part quoted above requires _resultat to be an int type since you are using bit-level masking but later on you are doing floating point arithmetic. You just need two variables.
Try this:
case 12:
int temp;
temp = _Buffer[0]; //originally assigning _resultat to the first byte
temp&=0b00001111; //ANDING this to 'mask' the unwanted bits
temp = temp << 8; //Shifting 8 bits in the MSB direction
temp |= _Buffer[1]; //OR to add byte 1 to the end of the first byte
if (temp>2048-1) {
temp=temp-4096-1; //this fixes the sign to be negative when needed
_resultat = ((float)temp/2047.0)*(2.048/(float)_PGA)*(180.0/33.0);
That sorted it, thank you so much!
@thanks for the backup @bko
@joearkay If it is not too much trouble would you be willing to share your code?
I am just beginning to work with the MCP3424 and would greatly appreciate the help.
Also thanks for starting this thread! It has been quite informative!
Hi @zferrie, sorry for the slow response. I used the library provided by the Arduino IDE, found here:
There was a small amount of modification to be done (can’t remember what I had to change), from memory, but this library worked really well.
I hope that helps.
@joearkay No worries. Based on the thread i wasn’t 100% on which of the two originally mentioned libraries you ended up using. This gives me a good place to start.
Thanks for the help!
Hi @zferrie, no worries, let me know if you need any assistance. Like I said, I worked on this project a while ago and am no longer using the codebase, so don’t have a full version I can share.
@joearkay Sounds great! Thank you!
