Please see this post for the layout of the board:
Thanks for reiterating that! I thought I had seen it before but my eyes failed to find it. (I guess a simple āfind in pageā would have worked well!)
Iām playing around with my ST-Link and I can get it to connect to my board from the ST-Link Utility but when using the st-util from the command line it seems to be having problems. It also wonāt program the chip. Here is the output from st-util:
C:\Users\xxxxx>st-util -m -p 9025
STLINK GDB Server v0.5.6 (Mar 24 2013 10:29:19)
Many thanks to the STLINK development team.
(https://github.com/texane/stlink)
2014-12-17T11:32:06 INFO src/stlink-common.c: Loading device parameters....
2014-12-17T11:32:06 WARN src/stlink-common.c: unknown chip id! 0xe0042000
Chip ID is 00000000, Core ID is 00000000.
KARL - should read back as 0x03, not 60 02 00 00
Listening at *:9025...
So I did some digging to see if there was something similar to the āhold in resetā for the st-util but no luck.
However, there was one lucky find in my digging. I solved the need for the patch file to keep restarting st-util. There is a command line option -m that causes the server to keep running after a disconnect and listen for another connection.
Any ideas on why the st-util is not able to properly connect? Thanks!
It sounds like you have not recompiled the core with USE_SWD_JTAG=y.
If you merge my pull request for just SWD support, you can use USE_SWD=y
See https://github.com/spark/firmware/pull/337
You need to compile the code with that flag and flash it via DFU before you can connect via SWD.
St-util will then find a Core ID that is not zero.
Thanks! Getting much closer now! The problem was that I had not uploaded firmware that I had compiled with the USE_SWD_JTAG=y with DFU.
Now my problem is when I try to attach the debugger I used the command that you showed and I get the following error:
Undefined target command: \"target remote localhost:9025\". Try \"help target\".
I have no idea where I could even try āhelp targetā because it gives me an error if I try setting that in the target text box. I also tried Google and it did not turn up anything.
I tried it without the leading ātargetā since the gdbserver plugin suggested a target of āremote host:portā when I first started the attach. However this appears to do nothing as I donāt see anything happen in the st-util window and I donāt seem to be able to interact with the board from NetBeans.
Thanks again for all of your help!
Do you have the quotes (") in the command?
Originally I did not have quotes in the command. I just tried it with the quotes and it behaves the same way.
@Elco, iām trying to setup the same environment on my MAC so that i can dig a little deeper on issues. However, iām getting the exact same warning for the chip id.
I have the JTAG shield and STlink V2 so hardware should be fine. If i found anything iāll update this post
UPDATE
If you hold on the RST button before invoking st-util -p 9025, the correct core id is displayed but the user firmware does not run.
@kennethlimcp, sounds like you have not enabled debugging in your firmware build:
@Sailing_Nut
Try without ātargetā: just remote localhost:9025
Thatās how I have it set up now.
Iāve tried it with the command being just:
and it looks like NetBeans never tries to attach to the GDB server. I see that it is listening on port 9025 and nothing happens.
I have also noticed that my āRunā command seems to stay attached to the DGB server so I am pressing the X to stop the run before I try to attach the debugger. (I also tried it without stopping the run before attaching and still nothing.)
I left NetBeans in the āattach to GDBā mode and I came back a while later and saw that an error had popped up. It states:
Malformed response to offset query, timeout
Not sure if that helps anything but wanted to report just in case!
In the meantime I figured out how to get the GDB output from NetBeans. Hope this helps! (I did not get anything significant from Google)
This log is saved to: C:\Users\********\AppData\Local\Temp\gdb-cmds8972465870749292784.log
NB build: 201411181905
=thread-group-added,id="i1"
~"GNU gdb (GNU Tools for ARM Embedded Processors) 7.6.0.20140529-cvs\n"
~"Copyright (C) 2013 Free Software Foundation, Inc.\n"
~"License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>\nThis is free software: you are free to change and redistribute it.\nThere is NO WARRANTY, to the extent permitted by law. Type \"show copying\"\nand \"show warranty\" for details.\n"
~"This GDB was configured as \"--host=i686-w64-mingw32 --target=arm-none-eabi\".\nFor bug reporting instructions, please see:\n"
~"<http://www.gnu.org/software/gdb/bugs/>.\n"
=cmd-param-changed,param="remote hardware-watchpoint-limit",value="6"
=cmd-param-changed,param="remote hardware-breakpoint-limit",value="4"
&"C:\\\\Users\\\\********\\\\Documents\\\\SparkDev\\\\WirelessGague1\\\\firmware\\\\gdbattach.txt:6: Error in sourced command file:\n"
&"The program is not being run.\n"
(gdb)
2-list-features
3info signals
4-gdb-set print repeat 0
5-gdb-set backtrace limit 1024
6-gdb-set print elements 400
7-gdb-set follow-fork-mode parent
8-gdb-set detach-on-fork on
9-enable-pretty-printing
10-file-exec-and-symbols "C:/Users/********/Documents/SparkDev/WirelessGague1/firmware/build/target/main/prod-0/main.elf"
2^done,features=["frozen-varobjs","pending-breakpoints","thread-info","data-read-memory-bytes","breakpoint-notifications","ada-task-info"]
(gdb)
&"info signals\n"
~"Signal Stop\tPrint\tPass to program\tDescription\n"
~"\n"
~"SIGHUP Yes\tYes\tYes\t\tHangup\n"
~"SIGINT Yes\tYes\tNo\t\tInterrupt\n"
~"SIGQUIT Yes\tYes\tYes\t\tQuit\n"
~"SIGILL Yes\tYes\tYes\t\tIllegal instruction\n"
~"SIGTRAP Yes\tYes\tNo\t\tTrace/breakpoint trap\n"
~"SIGABRT Yes\tYes\tYes\t\tAborted\n"
~"SIGEMT Yes\tYes\tYes\t\tEmulation trap\n"
~"SIGFPE Yes\tYes\tYes\t\tArithmetic exception\n"
~"SIGKILL Yes\tYes\tYes\t\tKilled\n"
~"SIGBUS Yes\tYes\tYes\t\tBus error\n"
~"SIGSEGV Yes\tYes\tYes\t\tSegmentation fault\n"
~"SIGSYS Yes\tYes\tYes\t\tBad system call\n"
~"SIGPIPE Yes\tYes\tYes\t\tBroken pipe\n"
~"SIGALRM No\tNo\tYes\t\tAlarm clock\n"
~"SIGTERM Yes\tYes\tYes\t\tTerminated\n"
~"SIGURG No\tNo\tYes\t\tUrgent I/O condition\n"
~"SIGSTOP Yes\tYes\tYes\t\tStopped (signal)\n"
~"SIGTSTP Yes\tYes\tYes\t\tStopped (user)\n"
~"SIGCONT Yes\tYes\tYes\t\tContinued\n"
~"SIGCHLD No\tNo\tYes\t\tChild status changed\n"
~"SIGTTIN Yes\tYes\tYes\t\tStopped (tty input)\n"
~"SIGTTOU Yes\tYes\tYes\t\tStopped (tty output)\n"
~"SIGIO No\tNo\tYes\t\tI/O possible\n"
~"SIGXCPU Yes\tYes\tYes\t\tCPU time limit exceeded\n"
~"SIGXFSZ Yes\tYes\tYes\t\tFile size limit exceeded\n"
~"SIGVTALRM No\tNo\tYes\t\tVirtual timer expired\n"
~"SIGPROF No\tNo\tYes\t\tProfiling timer expired\n"
~"SIGWINCH No\tNo\tYes\t\tWindow size changed\n"
~"SIGLOST Yes\tYes\tYes\t\tResource lost\n"
~"SIGUSR1 Yes\tYes\tYes\t\tUser defined signal 1\n"
~"SIGUSR2 Yes\tYes\tYes\t\tUser defined signal 2\n"
~"SIGPWR Yes\tYes\tYes\t\tPower fail/restart\n"
~"SIGPOLL No\tNo\tYes\t\tPollable event occurred\n"
~"SIGWIND Yes\tYes\tYes\t\tSIGWIND\n"
~"SIGPHONE Yes\tYes\tYes\t\tSIGPHONE\n"
~"SIGWAITING No\tNo\tYes\t\tProcess's LWPs are blocked\n"
~"SIGLWP No\tNo\tYes\t\tSignal LWP\n"
~"SIGDANGER Yes\tYes\tYes\t\tSwap space dangerously low\n"
~"SIGGRANT Yes\tYes\tYes\t\tMonitor mode granted\n"
~"SIGRETRACT Yes\tYes\tYes\t\tNeed to relinquish monitor mode\n"
~"SIGMSG Yes\tYes\tYes\t\tMonitor mode data available\n"
~"SIGSOUND Yes\tYes\tYes\t\tSound completed\n"
~"SIGSAK Yes\tYes\tYes\t\tSecure attention\n"
~"SIGPRIO No\tNo\tYes\t\tSIGPRIO\n"
~"SIG33 Yes\tYes\tYes\t\tReal-time event 33\n"
~"SIG34 Yes\tYes\tYes\t\tReal-time event 34\n"
~"SIG35 Yes\tYes\tYes\t\tReal-time event 35\n"
~"SIG36 Yes\tYes\tYes\t\tReal-time event 36\n"
~"SIG37 Yes\tYes\tYes\t\tReal-time event 37\n"
~"SIG38 Yes\tYes\tYes\t\tReal-time event 38\n"
~"SIG39 Yes\tYes\tYes\t\tReal-time event 39\n"
~"SIG40 Yes\tYes\tYes\t\tReal-time event 40\n"
~"SIG41 Yes\tYes\tYes\t\tReal-time event 41\n"
~"SIG42 Yes\tYes\tYes\t\tReal-time event 42\n"
~"SIG43 Yes\tYes\tYes\t\tReal-time event 43\n"
~"SIG44 Yes\tYes\tYes\t\tReal-time event 44\n"
~"SIG45 Yes\tYes\tYes\t\tReal-time event 45\n"
~"SIG46 Yes\tYes\tYes\t\tReal-time event 46\n"
~"SIG47 Yes\tYes\tYes\t\tReal-time event 47\n"
~"SIG48 Yes\tYes\tYes\t\tReal-time event 48\n"
~"SIG49 Yes\tYes\tYes\t\tReal-time event 49\n"
~"SIG50 Yes\tYes\tYes\t\tReal-time event 50\n"
~"SIG51 Yes\tYes\tYes\t\tReal-time event 51\n"
~"SIG52 Yes\tYes\tYes\t\tReal-time event 52\n"
~"SIG53 Yes\tYes\tYes\t\tReal-time event 53\n"
~"SIG54 Yes\tYes\tYes\t\tReal-time event 54\n"
~"SIG55 Yes\tYes\tYes\t\tReal-time event 55\n"
~"SIG56 Yes\tYes\tYes\t\tReal-time event 56\n"
~"SIG57 Yes\tYes\tYes\t\tReal-time event 57\n"
~"SIG58 Yes\tYes\tYes\t\tReal-time event 58\n"
~"SIG59 Yes\tYes\tYes\t\tReal-time event 59\n"
~"SIG60 Yes\tYes\tYes\t\tReal-time event 60\n"
~"SIG61 Yes\tYes\tYes\t\tReal-time event 61\n"
~"SIG62 Yes\tYes\tYes\t\tReal-time event 62\n"
~"SIG63 Yes\tYes\tYes\t\tReal-time event 63\n"
~"SIGCANCEL No\tNo\tYes\t\tLWP internal signal\n"
~"SIG32 Yes\tYes\tYes\t\tReal-time event 32\n"
~"SIG64 Yes\tYes\tYes\t\tReal-time event 64\n"
~"SIG65 Yes\tYes\tYes\t\tReal-time event 65\n"
~"SIG66 Yes\tYes\tYes\t\tReal-time event 66\n"
~"SIG67 Yes\tYes\tYes\t\tReal-time event 67\n"
~"SIG68 Yes\tYes\tYes\t\tReal-time event 68\n"
~"SIG69 Yes\tYes\tYes\t\tReal-time event 69\n"
~"SIG70 Yes\tYes\tYes\t\tReal-time event 70\n"
~"SIG71 Yes\tYes\tYes\t\tReal-time event 71\n"
~"SIG72 Yes\tYes\tYes\t\tReal-time event 72\n"
~"SIG73 Yes\tYes\tYes\t\tReal-time event 73\n"
~"SIG74 Yes\tYes\tYes\t\tReal-time event 74\n"
~"SIG75 Yes\tYes\tYes\t\tReal-time event 75\n"
~"SIG76 Yes\tYes\tYes\t\tReal-time event 76\n"
~"SIG77 Yes\tYes\tYes\t\tReal-time event 77\n"
~"SIG78 Yes\tYes\tYes\t\tReal-time event 78\n"
~"SIG79 Yes\tYes\tYes\t\tReal-time event 79\n"
~"SIG80 Yes\tYes\tYes\t\tReal-time event 80\n"
~"SIG81 Yes\tYes\tYes\t\tReal-time event 81\n"
~"SIG82 Yes\tYes\tYes\t\tReal-time event 82\n"
~"SIG83 Yes\tYes\tYes\t\tReal-time event 83\n"
~"SIG84 Yes\tYes\tYes\t\tReal-time event 84\n"
~"SIG85 Yes\tYes\tYes\t\tReal-time event 85\n"
~"SIG86 Yes\tYes\tYes\t\tReal-time event 86\n"
~"SIG87 Yes\tYes\tYes\t\tReal-time event 87\n"
~"SIG88 Yes\tYes\tYes\t\tReal-time event 88\n"
~"SIG89 Yes\tYes\tYes\t\tReal-time event 89\n"
~"SIG90 Yes\tYes\tYes\t\tReal-time event 90\n"
~"SIG91 Yes\tYes\tYes\t\tReal-time event 91\n"
~"SIG92 Yes\tYes\tYes\t\tReal-time event 92\n"
~"SIG93 Yes\tYes\tYes\t\tReal-time event 93\n"
~"SIG94 Yes\tYes\tYes\t\tReal-time event 94\n"
~"SIG95 Yes\tYes\tYes\t\tReal-time event 95\n"
~"SIG96 Yes\tYes\tYes\t\tReal-time event 96\n"
~"SIG97 Yes\tYes\tYes\t\tReal-time event 97\n"
~"SIG98 Yes\tYes\tYes\t\tReal-time event 98\n"
~"SIG99 Yes\tYes\tYes\t\tReal-time event 99\n"
~"SIG100 Yes\tYes\tYes\t\tReal-time event 100\n"
~"SIG101 Yes\tYes\tYes\t\tReal-time event 101\n"
~"SIG102 Yes\tYes\tYes\t\tReal-time event 102\n"
~"SIG103 Yes\tYes\tYes\t\tReal-time event 103\n"
~"SIG104 Yes\tYes\tYes\t\tReal-time event 104\n"
~"SIG105 Yes\tYes\tYes\t\tReal-time event 105\n"
~"SIG106 Yes\tYes\tYes\t\tReal-time event 106\n"
~"SIG107 Yes\tYes\tYes\t\tReal-time event 107\n"
~"SIG108 Yes\tYes\tYes\t\tReal-time event 108\n"
~"SIG109 Yes\tYes\tYes\t\tReal-time event 109\n"
~"SIG110 Yes\tYes\tYes\t\tReal-time event 110\n"
~"SIG111 Yes\tYes\tYes\t\tReal-time event 111\n"
~"SIG112 Yes\tYes\tYes\t\tReal-time event 112\n"
~"SIG113 Yes\tYes\tYes\t\tReal-time event 113\n"
~"SIG114 Yes\tYes\tYes\t\tReal-time event 114\n"
~"SIG115 Yes\tYes\tYes\t\tReal-time event 115\n"
~"SIG116 Yes\tYes\tYes\t\tReal-time event 116\n"
~"SIG117 Yes\tYes\tYes\t\tReal-time event 117\n"
~"SIG118 Yes\tYes\tYes\t\tReal-time event 118\n"
~"SIG119 Yes\tYes\tYes\t\tReal-time event 119\n"
~"SIG120 Yes\tYes\tYes\t\tReal-time event 120\n"
~"SIG121 Yes\tYes\tYes\t\tReal-time event 121\n"
~"SIG122 Yes\tYes\tYes\t\tReal-time event 122\n"
~"SIG123 Yes\tYes\tYes\t\tReal-time event 123\n"
~"SIG124 Yes\tYes\tYes\t\tReal-time event 124\n"
~"SIG125 Yes\tYes\tYes\t\tReal-time event 125\n"
~"SIG126 Yes\tYes\tYes\t\tReal-time event 126\n"
~"SIG127 Yes\tYes\tYes\t\tReal-time event 127\n"
~"SIGINFO Yes\tYes\tYes\t\tInformation request\n"
~"EXC_BAD_ACCESS Yes\tYes\tYes\t\tCould not access memory\n"
~"EXC_BAD_INSTRUCTION Yes\tYes\tYes\t\tIllegal instruction/operand\n"
~"EXC_ARITHMETIC Yes\tYes\tYes\t\tArithmetic exception\n"
~"EXC_EMULATION Yes\tYes\tYes\t\tEmulation instruction\n"
~"EXC_SOFTWARE Yes\tYes\tYes\t\tSoftware generated exception\n"
~"EXC_BREAKPOINT Yes\tYes\tYes\t\tBreakpoint\n"
~"\nUse the \"handle\" command to change these tables.\n"
3^done
(gdb)
4^done
(gdb)
5^done
(gdb)
6^done
(gdb)
7^done
(gdb)
8^done
(gdb)
9^done
(gdb)
10^done
11cd C:\Users\********\Documents\SparkDev\WirelessGague1\firmware\build\target\main\prod-0
12-exec-arguments main.elf -x C:\Users\********\Documents\SparkDev\WirelessGague1\firmware\gdbprogram.txt
(gdb)
&"cd C:\\Users\\********\\Documents\\SparkDev\\WirelessGague1\\firmware\\build\\target\\main\\prod-0\n"
~"Working directory C:\\Users\\********\\Documents\\SparkDev\\WirelessGague1\\firmware\\build\\target\\main\\prod-0.\n"
11^done
(gdb)
=cmd-param-changed,param="args",value="main.elf -x C:\\\\Users\\\\********\\\\Documents\\\\SparkDev\\\\WirelessGague1\\\\firmware\\\\gdbprogram.txt"
12^done
(gdb)
13target remote localhost:9025
&"target remote localhost:9025\n"
~"Remote debugging using localhost:9025\n"
~"Ignoring packet error, continuing...\n"
&"warning: unrecognized item \"timeout\" in \"qSupported\" response\n"
=thread-group-started,id="i1",pid="42000"
=thread-created,id="1",group-id="i1"
=thread-group-exited,id="i1"
&"Malformed response to offset query, timeout\n"
13^error,msg="Malformed response to offset query, timeout"
(gdb)
Yes, you have to make sure you have no old processes running in the background, or you will not be able to attach.
OK, so I found out that my little -m discovery was my undoing!
I ran a test without first doing the ārunā command just to see if my firewall was getting in the way. Well, the debug session attached! So I terminated that and then tried a ārunā but that failed to attach to the GDB server.
So, the problem is that st-util.exe is not actually accepting connections after a process detaches even though it looks like it is waiting.
I revised my āprocessā to use the batch file and all is happy now!
Thanks for all of your help!
@mdma notified me that there is an open bug report for not being able to pause execution in Netbeans.
Please help give the bug priority by creating an account and voting on the issue:
https://netbeans.org/bugzilla/show_bug.cgi?id=224840
I wrote a shell script for easy and reliable programming via GDB:
Please see:
https://github.com/BrewPi/firmware/blob/develop/tools/hardware_debugging.md
and
This script will start st-util, then fork it to the background and start arm gdb to connect to it and upload the code. After that it does a clean exit: no lingering processes that you should remember to close.
You can just set this script as the run command in NetBeans and it will upload the code with 1 click. The output of the script will be printed in the embedded terminal.
After you have uploaded the code, if needed, you can start st-util again and connect the debugger.
I think the process is great now, it just misses the ability to pause. This is related to the bug report I posted above, donāt forget to vote for it!
Hi @Elco !
Thanks for this tutorial. In my quest for setting up an working debug environment for Photon it was time for NetBean.
I have followed your guide but when I should connect to the target I get this error.
āC:\Particle\Toolchain\GCC-ARM\bin\arm-none-eabi-gdb.exeā: not in executable format: File format not recognized
I use NetBean 8.0.2, Have you tried this version? I have not double \ in the link to gdb but it seams NetBean add this⦠:-/
I also would love to get this going for photon. Iāll try it but Iām not optimistic.
I would just like to say that I have switched to Eclipse for my Photon/Spark development.
It offers 2 huge benefits while step debugging:
- A working pause button
- A button to enable/disable ALL breakpoints, which can be toggled at any time, even when running.
To debug, I run st-util externally, in a command prompt. In eclipse, I use āGDB Hardware Debuggingā (which I think is a plugin), with GDB command āarm-none-eabi-gdbā and remote target localhost:4242.
I donāt have time to post more details, as I am going on holiday in 2 days. Just a quick note that Eclipse beats NetBeans in debugging capabilities.
Now that I think about it, I once sent in a pull request (which was accepted) to enable just SWD (without JTAG) on the Spark Core, by defining USE_SWD=y
On the Photon, this is not working. Can we get that option back in?
