Latest firmware released to Spark Build
HI @luz and @BDub
It would be very interesting to see the numbers coming out of gcc after a local compile. There can be a lot of FLASH used by the new firmware if you don't throw the right panic switch, but there was only a very modest increase in RAM used.
RAM is data+bss since data represents variable initializer values.
