Now receive it:
Program Start
Executing Curl Operation
Curl Result: ''
Program End
Now receive it:
Program Start
Curl Result: ''
Program End
How about you change your access token and device ID to dummy values and change the `$url = …" to
$url = 'http://requestb.in/11fj1ll1' . $deviceID . '/' + $deviceFunction ;
Run it and then let me know so I can look at the request?
crazy, nothing received
How about something simple, like this:
<?php
$result = file_get_contents('http://requestb.in/11fj1ll1');
echo $result;
Perhaps curl is disabled on your server?
An OK message received
I found that curl code working in my computer, but it get an information from spark
$url = 'https://api.spark.io/v1/devices/aaaaaa/result/?access_token=aaaaaaaa';
// Initiate curl
$ch = curl_init();
// Disable SSL verification
curl_setopt($ch, CURLOPT_SSL_VERIFYPEER, false);
// Will return the response, if false it print the response
curl_setopt($ch, CURLOPT_RETURNTRANSFER, true);
// Set the url
curl_setopt($ch, CURLOPT_URL,$url);
// Execute
$result=curl_exec($ch);
// Closing
curl_close($ch);
Ah, I was thinking that perhaps it didn’t like the SSL part. I updated the gist. Give that a try
made the test, nothing yet
Well, I do apologize. I will test this when I get home and get it working. I’ll reply when I do
[Edit] Should be free in about 2 to 3 hours
Ok thank you very much, I’m waiting for your answer.
Sorry for the late response. I got… distracted ( http://community.spark.io/t/phpspark-interacting-with-the-spark-cloud-spark-io-using-php/10617/1 )
This should work for you (modify as your see fit)
<?php
// Include the required files. You will need to rename phpSpark.config.sample.php to phpSpark.config.php and then set the values within to use this example
if((@include 'phpSpark.class.php') === false) die("Unable to load phpSpark class");
if((@include 'phpSpark.config.php') === false) die("Unable to load phpSpark configuration file");
// Grab a new instance of our phpSpark object
$spark = new phpSpark();
// Set the internal debug to false. Note, calls made to $spark->debug(...) by you ignore this line and display always
$spark->setDebug(false);
// Set the debug calls to display pretty HTML format. Other option is "TEXT". Note, calls made to $spark->debug(...) display as set here
$spark->setDebugType("HTML");
// Set our access token (set in the phpConfig.config.php file)
$spark->setAccessToken($accessToken);
// Call a Spark Function
$spark->debug("Spark Function");
if($spark->doFunction($deviceID, "led", "l,HIGH") == true)
$spark->debug_r($spark->getResult());
else
$spark->debug("Error: " . $spark->getError());
$spark->debug("Error Source" . $spark->getErrorSource());
Hello,
I received this messages::
Spark Function
Notice: Undefined property: phpSpark::$disableSSL in …\phpSpark.class.php on line 406
Error: Unable to parse JSON. Json error = 0. See http://php.net/manual/en/function.json-last-error.php for more information. Raw response from Spark Cloud = ‘’
Error SourcedoFunction
Thanks for catching that. You have your PHP enviroment set quite strict (which is good). I pushed an update to the repo. Let me know if that doesn’t fix the problem for you.
