To save you some reading ![]()
and the following post of the OP.
But it would still be interesting if @Dave found another solution.
I’m still tracking this down, sorry about the lack of news! You can also watch the responses from your hooks with the CLI with a quick spark subscribe mine
David
@dave when monitoring the webhook response through dashboard/curl/node.js it just sometimes does not come through.
I see my webserver giving an response when the core publishes towards the webhook. But somewhere somehow the response is just not received or handled by the Spark Cloud.
How may I be able to monitor this better than through dashboard/curl/node.js
Regards,
Bart
Hi @bartjenniskens,
Sorry about the slow reply, so much going on!
If your webserver doesn’t have any body in the http response, then the webhook won’t publish a response event. Can you make sure your server has a non-empty response?
David
Hi all,
It took me a good two hours (edit: just realised how much time has gone!) to trim down my code to the bare webhooks, delete/readd webhooks, test, test, google, test, test, google. You get the idea.
This is a definite bug, I can replicate it and I know via particle CLI that the hook-responses of both have valid data. The first webhook subscribed to gets called, not the second, when you are publishing to both. You guys have pretty good support - though can I suggest someone updates the docs example to show the webhookHandler approach with a note there is a pending bug with multiple subscribe/publish pairs?
For the time being I’ll steal the webhookHandler idea.
hate to ask, but has the behaviour suddenly changed?
subscribing to hook-response works, ‘hook-response/’ doesn’t appear to work anymore.
