How to use QSPI Flash on Boron
This declaration:
String* buf = new String[100];
creates an array of 100 String objects that are empty, not something you can read data into using read().
@joe_boron, by default, and array name is a pointer. @rickkas7 shows char buf[100] where buf is, by default, the pointer to buf[0].
Then, how would I delete the data or the files I wrote to the flash? Would I use the rmdir command?
To delete a file from the file system:
unlink("/usr/test1.txt");
