@dcliff9 you’ll be happy to hear that I got it working. Your advice was all correct – but a few things were tripping me up. I’ll write them down in case someone else runs into the same snags:
- In the switch you provided in the handler, I was using integers as cases, not the provided particle system enums. Because I was using
all_events
these ints were interfering with other system values that had the same int value. - I was triggering the
Particle.process
in the loop, but only once, not in awhile
block.
That’s it. The rest was just time and making sure that the code your provided was where you said it should be!
Thanks again
