Thanks @kennethlimcp
I’m using
and a port of this lib: https://github.com/adafruit/Adafruit-RGB-LCD-Shield-Library
by @mumblepins : https://github.com/mumblepins/Adafruit_RGBLCDShield
discussed in this thread:
Having some trouble getting code to compile
The problem I have with Particle Dev is that it doesn’t seem to work at all
Here’s what happens when I try to “compile and upload”
I can’t seem to get libraries added to code at all through Particle Dev.
RE: DHT lib, the piettech lib seems to work, so I’m okay with that. Why the adafruit_dht lib works for some apps and not for others seems like a Particle issue.
Here’s a screencap video of the balkiness removing a library. I don’t always get this problem, or the problem when adding libraries, but this should give you some idea.
I also got a screencap of a 500 error, but that’s not a very enlightening video.
It happens just enough to be really irritating, particularly when I can’t flash from the local IDE.
