EventStream or WebHooks?
Server Sent Events are usually better if:
  • You are running the server at home or small business with a non-static IP address.
  • You don’t want to go through the time and expense of setting up SSL certificates for your server.
  • Generally no firewall rules or port forwarding to worry about as the connection is outbound.
  • You want slightly lower latency for event notification.
Webhooks are better if:
  • You need to distribute the handling across multiple servers. (This also improves reliability through redundancy.)
  • You are sensitive to lost events. (With SSE, if the connection goes down, it can take a while, up to a minute, for this to be noticed and corrected. In the downtime, any events sent during that period will be lost.)
Google Pubsub is better if:
  • You are sensitive to lost events. With Google Pubsub, once the event is delivered to the Google cloud, they are buffered there. This means if your server is unreachable or down you won’t lose events.
  • Or your server is still in development and may not have 100% uptime yet.
  • Once Google Pubsub events are received by the Google cloud they have confirmed delivery so you can have multiple event servers that handle events to distribute load and for redundancy without getting duplicates.
