Hello,
can everyone help me pleas.
i testet SPS30 sensor but when i make release becom this error:
pi@raspberrypi:~ $ make release
make: *** No rule to make target ‘release’. Stop.
thank you
mike
Hello,
thank you
mike
@mike197678, this is a forum for the Particle family of devices. It is not clear for what Particle device you are seeking help with. By the looks of it, you may be in the wrong forum.
Hello
I read above in a post about a raspberry pi and the sps30 sensor.
Post from @Eugene1
my hardware is a Raspberry pi 3
and a SPS30 from Sensirion
unfortunately i am a newcomer and wanted to get this sensor up and running.
Can nobody help me?
It appears you’ve forgotten to cd
into the repository that you cloned. Once you are in the directory you should be able to follow the rest of the instructions.
This is a forum for Particle devices however, so if you require additional help I would recommend posting in a Raspberry Pi oriented forum.
I used pms7003 with pi3b+ and i can run it ,
but now i want record ,or send data to Thingspeak,
but i don’t know how to do
can nobody help me?
Hello, the same problem is happening to me, did you find a solution? or does anyone know how to make the pms5003 work on Boron?
