DIGITAL GPIO start-up glitch
I solved this very simply by using the fast io functions to set the desired initial value before configuring as an output and thus driving the output line.
   pinSetFast(pin); // initialize to HIGH
   pinSetMode(pin, OUTPUT);  // enable output
or
   pinResetFast(pin); // initialize to LOW
In reality, the library should have a setPinMode that takes a third argument which is the initial value. In my case I have some outputs that are active low and some that are active hi so I wrote a generic wrapper so I can change an output from active high to active low later and not worry about spreading HIGH and LOW around my code:
See my post here for details,
