Great idea! Thanks ScruffR!
So, just for posterity⦠incase anyone else wants to copy⦠hereās the final version.
Servo timservo;
int position = 0; // variable to store the servo position
int newposition = 0;
//Setup the Servo to the function
Particle.function("timservo", updatetimServo);
//Set pin D0 to be an output
pinMode(D0, OUTPUT);
//Take control over the LED on the board
RGB.control(true);
//There may be a better way to do this like turning it off, I found it just as easy to set the colour to nothing
RGB.color(0, 0, 0);
//This function is triggered by IFTTT - the 'command' word represents the object used to store the 'position' we send to the function.
//The 'position' we send represents where we want the servo to move to
int updatetimServo(String command)
newposition = command.toInt();
// 0deg
if (newposition == 1) {
switch(position) {
case 2:
timservo.write( 100 );
delay( 1000 );
timservo.write( 90 );
break;
case 3:
delay( 2000 );
break;
case 4:
delay( 3000 );
default:
return -1;
// 45deg
if (newposition == 2) {
switch(position) {
case 1:
timservo.write( 80 );
delay( 1000 );
break;
case 3:
delay( 1000 );
break;
case 4:
delay( 2000 );
default:
return -1;
// 90deg
if (newposition == 3) {
switch(position) {
case 1:
delay( 2000 );
break;
case 2:
delay( 1000 );
break;
case 4:
delay( 1000 );
break;
default:
return -1;
// 135deg
if (newposition == 4) {
switch(position) {
case 1:
delay( 3000 );
break;
case 2:
delay( 2000 );
break;
case 3:
delay( 1000 );
break;
default:
return -1;
position = newposition;
return position;
Now that youāve got that working, try moving the logic from the function handler to the loop, since itās bad practice (and often problematic) to have functions block for a long time. Try keeping them as short as possible.
Thatās a great idea Moors7. Not sure where to begin, but I guess thatās part of the fun. Iām sure I canāt be the only one who struggles with these things. Are there any good learning materials out there? Iāve been through the documentation on the particle.io site but that only takes me so far.
Weāve all been there (heck, Iām still there ;)). I personally like to learn by picking a project and figuring things out as I go. Then you do something thatās useful to you, so itās easier to put in the effort. I know there are some books out there with several beginner project that might help get you started. Simon Monk has written one that I know of. That said, I havenāt tried any of those, so no guarantees as to whatās in there.
I agree on the figuring out thing. My only issue is that once something works, often I have no idea why it works. I certainly, more often than not, have no idea how to then improve upon it (as you suggested above). Iāve done this one by going backwards and forwards through this forum picking up on bits (and lots of help from nice people). Itās the basics of āhow to send a function to the loopā that I just donāt have a handle on.
Iād love to work out how stepper motors work too, but there doesnāt seem to be any literature out there with just a basic, ābuy this, do this⦠see, it works and hereās whyā⦠so I have literally no idea where to begin. Does that make sense?
The way you currently use the function is to send it a new variable, and then immediately check/act upon that variable. Rather than doing that 'hard work' in the function, simply check for it in the loop.
Some extremely simplified code would be:
loop() {
if (should_I_do_the_thing == true){
do_the_thing();
should_I_do_the_thing = false;
//function call
int thing_function(String command){
should_I_do_the_thing = true;
return 1;
Thanks Moors7, I think that helped a lot.
So, it would look like this? (seems to verify ok⦠which I find shocking!!)
Servo timservo;
bool makeachange = false;
RGB.control(true);
RGB.color(0, 0, 0);
if ( makeachange == true) {
// 0deg
switch(position) {
case 2:
delay( 1000 );
break;
case 3:
delay( 2000 );
break;
case 4:
delay( 3000 );
break;
// 45deg
switch(position) {
case 1:
delay( 1000 );
break;
case 3:
delay( 1000 );
break;
case 4:
delay( 2000 );
break;
// 90deg
switch(position) {
case 1:
delay( 2000 );
break;
case 2:
delay( 1000 );
break;
case 4:
delay( 1000 );
break;
// 135deg
switch(position) {
case 1:
delay( 3000 );
break;
case 2:
delay( 2000 );
break;
case 3:
delay( 1000 );
break;
makeachange = true;
return position;
