Thanks for your reply
i’ve make some mod ed now it seems to work
i’ve mod the payload lenght to max 240 and mod the reconnect function and pir controller function like as you had already suggested me in the post: Mqtt library and pinmode error
In addition I have also modified the provision of the Code:
* Project TIni2
* Description:
* Author:
* Date:
#include <MQTT.h>
#include <ArduinoJson.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_BME280.h>
#include <EmonLib.h>
#define RELAY_PIN D7
#define PIR_PIN D1
#define BME_SCK D4
#define BME_MISO D3
#define BME_MOSI D2
#define BME_CS D5
#define SEALEVELPRESSURE_HPA (1013.25)
#define SENSORNUMBER (7)
#define SERSORNAME "Clientino"
typedef struct
char* sensortype;
char* sensorunit;
char* sensorID;
} sensor_conf;
typedef struct
char macStr[19];
sensor_conf sens[SENSORNUMBER];
} tini_conf;
typedef struct
String topic;
String message;
} mqtt_message;
mqtt_message mmessage;
tini_conf tini;
byte mac[6];
char macStr[19];
int prevState = 0;
uint32_t lastTime;
void callback(char* topic, byte* payload, unsigned int length);
void initcicle(const char* t, const char* u, const char* i);
void init ();
void publishjson(int id, float value);
void bme_controller();
void pir_controller();
void ct_controller();
void reconnect();
MQTT client("aisens.beiot.cloud", 1883, callback);
Adafruit_BME280 bme(BME_CS, BME_MOSI, BME_MISO, BME_SCK);
EnergyMonitor emon1;
// setup() runs once, when the device is first turned on.
Serial.begin(9600);
Serial.println("Photon setup starts!");
Particle.syncTime();
Time.zone(1);
while(!bme.begin());
emon1.current(1, 26.6);
WiFi.macAddress(mac);
snprintf(macStr, sizeof(macStr), "T%02x%02x%02x%02x%02x%02x", mac[0], mac[1], mac[2], mac[3], mac[4], mac[5]);
strcpy (tini.macStr, macStr);
client.connect(SERSORNAME);
tini.sens[1].sensortype = "Temperature";
tini.sens[1].sensorunit = "Celsius";
tini.sens[1].sensorID = "00";
tini.sens[2].sensortype = "Pressure";
tini.sens[2].sensorunit = "HPA";
tini.sens[2].sensorID = "00";
tini.sens[3].sensortype = "Altitude";
tini.sens[3].sensorunit = "Meter";
tini.sens[3].sensorID = "00";
tini.sens[4].sensortype = "Humidity";
tini.sens[4].sensorunit = "Rate";
tini.sens[4].sensorID = "00";
tini.sens[5].sensortype = "PIR";
tini.sens[5].sensorunit = "Digital";
tini.sens[5].sensorID = "00";
tini.sens[6].sensortype = "Apparent Power";
tini.sens[6].sensorunit = "Watt";
tini.sens[6].sensorID = "00";
tini.sens[7].sensortype = "Current";
tini.sens[7].sensorunit = "Ampere";
tini.sens[7].sensorID = "00";
tini.sens[8].sensortype = "Relay";
tini.sens[8].sensorunit = "Digital";
tini.sens[8].sensorID = "00";
if (client.isConnected()) {
client.publish(String("lasttime/")+tini.macStr, "pluto"); //publish time starts up
client.subscribe(String(tini.macStr) + "/" + tini.sens[8].sensortype + "/" + tini.sens[8].sensorID);
delay(100);
init();
pinMode(RELAY_PIN, OUTPUT);
pinMode(PIR_PIN, INPUT);
pinMode(D7, OUTPUT);
lastTime = millis();
client.publish(String("lasttime/")+tini.macStr, "paperina");
Serial.println("Photon setup end!");
Serial.println("Photon loop start!");
Serial.println("Photon loop if start!");
client.loop();
pir_controller();
if(millis() - lastTime > 15000){
//init();
bme_controller();
delay(100);
ct_controller();
delay(100);
Serial.println("Photon loop if end!");
else
Serial.println("Photon else start!");
reconnect();
if(!client.isConnected()){
String message7 = Time.timeStr();
char cstr[24];
strcpy(cstr, message7.c_str());
client.publish(String("lasttime/")+tini.macStr, "pippo"); //publish time starts up
delay(100);
Serial.println("Photon else end!");
Serial.println("Photon loop end!");
void reconnect() {
if(!Particle.connected()) {
Particle.connect();
waitUntil(Particle.connected);
void ct_controller(){
double Irms = emon1.calcIrms(1480); // Calculate Irms only
publishjson(6, Irms*230.0); // Apparent power
publishjson(7, Irms); // Irms
delay(100);
void pir_controller(){
/*if (digitalRead(PIR_PIN) == HIGH && !pir_state){
publishjson(5, 1);
pir_state = true;
else if (digitalRead(PIR_PIN) == LOW && pir_state){
publishjson(5, 0);
pir_state = false;
int currState = digitalRead(PIR_PIN);
Serial.printlnf("%d (%8u)", currState, millis());
if (currState != prevState) {
prevState = currState;
publishjson(5, currState);
void bme_controller(){
publishjson(1, bme.readTemperature());
delay(100);
publishjson(2, bme.readPressure() / 100.00F);
delay(100);
publishjson(3, bme.readAltitude(SEALEVELPRESSURE_HPA));
delay(100);
publishjson(4, bme.readHumidity());
void publishjson(int id, float value) {
String topic = String(tini.macStr) + "/" + tini.sens[id].sensortype + "/" + tini.sens[id].sensorID;
StaticJsonBuffer<200> jsonBuffer;
JsonObject& root = jsonBuffer.createObject();
root["eventsensordatetime"] = millis();
root["eventsensorvalue"] = value;
char buffer[200];
root.prettyPrintTo(buffer, sizeof(buffer));
client.publish(topic, buffer);
void init (){
int i;
for (i=1; i<=SENSORNUMBER; i++){
initcicle(tini.sens[i].sensortype, tini.sens[i].sensorunit, tini.sens[i].sensorID);
delay(100);
void initcicle(const char* t, const char* u, const char* i) {
StaticJsonBuffer<240> jsonBuffer;
root["eventID"] = 1;
root["eventsensorname"] = tini.macStr;
root["eventsensortype"] = t;
root["eventsensorunit"] = u;
root["eventsensorID"] = i;
char buffer[300];
client.publish("init", buffer);
delay(100);
void callback(char* topic, byte* payload, unsigned int length) {
char p[length + 1];
memcpy(p, payload, length);
p[length] = NULL;
String message(p);
String t(topic);
mmessage.message = message;
mmessage.topic = t;
/*char p[length + 1];
p[length] = NULL;
String message(p);
if (message.equals("RED"))
RGB.color(255, 0, 0);
else if (message.equals("GREEN"))
RGB.color(0, 255, 0);
else if (message.equals("BLUE"))
RGB.color(0, 0, 255);
else
RGB.color(255, 255, 255);
delay(1000);*/
