Dave, I thought that only disabled the Spark Cloud connection, not the Spark-to-router connection. My understanding is he wants to decide when he connects to a router because there is not always one available.
@Dave -- @peekay123 is correct. Imagine you wanted to do your WiFi scanning, but wanted to walk around your neighborhood instead of staying at your house/lab (e.g. wardriving). @peekay123 mentioned WiFi profiles stored on the CC3000. If there was a way to clear those profiles out such that the CC3000 would not attempt to connect to a WiFi Access Point first then perhaps it would be a bit more cooperative?
Here's the other part of my project (performing scanning -- edited) :
@satishāgn THANK you.
@peekay123 @Dave, I took your advice and utilized the Spark.sleep(30) and it got similar results to turning off WiFi. I was doing a spark serial monitor and it kicked me out of the session. I saw this come back just before the device started flashing red:
events.js:72
throw er; // Unhandled 'error' event
Once I re-connect serial monitor I can see the device going through itās setup() again. Code looks like this:
#include "spark_disable_wlan.h"
#include "spark_disable_cloud.h"
#include "application.h"
void setup(){
Spark.disconnect();
WiFi.on();
Serial.println("here we go...");
void loop(){
structSSID();
Spark.sleep(30);
Any help you can provide would be truly appreciated.
gcoffee, I had previously written about waiting for wifi commands to complete:
You still need to do that around WiFi.on(). I don't see any Serial.begin() in your setup() so you won't get any serial connection and the serial port will not appear on the PC.
The flashing red (panic) is most likely caused by loop() being uncontrolled. What I mean by that is after your call to structSSID(), sleep is called and returns immediately. Only a flag is set for the wifi to go to standby. You then loop and do this endlessly which causes the processor to run out of memory. I suspect you thought the processor would go to sleep on that call but the documentation states:
Spark.sleep() can be used to dramatically improve the battery life of a Spark-powered project by temporarily deactivating the Wi-Fi module, which is by far the biggest power draw.
Perhaps if you explain what you are trying to achieve, I may be able to help you more. ![]()
@peekay123 ā you did mention that; and I had that code in there when I was doing the WiFi.on/off() commands. I didnāt think I still needed it with the Spark.sleep() command. Sorry to have bothered you on that.
You also mentioned that the WiFi.on() command will attempt to get an IP address. Iām assuming that if it doesnāt get an IP address then it will return a status of WIFI_CONNECTING?
gcoffee, I would venture to say yes, WiFi.status() will return CONNECTING though I am not sure there is a timerout. You may want to use a Serial.print() to see what it does.
With the new changes to firmware to accommodate all this WiFi.on and off, is spark.sleep(x) no longer working in itās simplest form? Sleep āseemsā to disconnect from the cloud for a specified amount of seconds, but power supply current doesnāt seem to drop like it did last week? Iām using a Dr Watson, so not getting the best of resolution of power consumption, but this code last week would go from .08 amps to .02 amps during the sleep cycle. There doesnāt seem to be any drop in power consumption at all, just stays at .08 amps all the time. Sleep was very convenient to go into a low power mode, and while the wifi.on and off seems to be more configurable, thereās a lot more code to go into a power saving mode. Can anyone confirm that there is no drop in supply current using this simple example? I could very well be overlooking somethingā¦
char LED = D7;
pinMode(LED, OUTPUT);
digitalWrite(LED, HIGH); //LED on initially
//Do something
delay(25000); //delay for 25 seconds
//Start sleep cycle
digitalWrite(LED, LOW); //LED off to indicate sleep
Spark.sleep(30); //sleep for 30 seconds
delay(30000); //delay for 30 seconds
digitalWrite(LED, HIGH); //LED back on
//End sleep cycle
brianr, your call to Spark.sleep(30) simply sets the CC3000 standby flag. Then, in the delay(30000), the Spark actually calls the SPARK_WLAN_Loop() background task which will see the sleep flag and put the CC3000 in standby. So the delay() will sit there and at about the time the delay finishes (30s), so will the CC3000 standby time and the CC3000 will wake.
Your loop() basically has the CC3000 ON for 25s then STANDBY for 30s and so on. During the ON time, the WiFi will attempt to connect to a router if a profile exists. You should see power go up and down from about 30-40ma to 150+ma when the CC3000 is attempting to connect. So you are saving power half the time of the loop().
Agreed, I should see full power consumption for 25 seconds, and then D7 should go off, CC3000 should go to āstandbyā, and power consumption should drop. Last week I saw exactly what was expected. Iāve been testing different scenarios for several days, even tried the second core that I have, and power consumption doesnāt change during the 30 seconds that the CC3000 is supposed to be in standby. Iām playing with the wifi.on and off right now, and I can get power consumption to drop to expected levels when the CC3000 is off.
Not sure why I didnāt do this before, but running the above code while doing a ping -t to the IP address of the core, it continues to ping while the core is supposed to be sleeping. I lose a few pings at the end of the sleep timeout, while the RGB flashes green to reconnect. I added in a variable that counts, which I can curl while the spark is awake, but canāt get while itās sleeping. This confirms my fear that while Spark.sleep(30); might be disconnecting from the cloud, it is not turning off the CC3000, and thus saving no power. Since this code is ultra simple, I canāt fathom that Iām overlooking something, am I?
Thanks for doing the test! I replicated the scenario and will bring it up to the
team tomorrow.
Will post an update if i hear anything!
There seems to be a lot of chatter and people interested in the low power modes of the CC3000 and the core in general. It might be worth checking into the Wifi.off() functions, as my ping testing reveals the same results, disconnects from the cloud, but continues to ping except for when reconnecting.
Cool. Iāll bring it up tomorrow
@brainr,
So the
Elites have brought this to the attention of the team and we will continue to push for this to be on the higher priority. Sit back and hope for good news the soonest possible
Have you heard any word from the team on this? Iāve got a spark coded and ready to go out into the field, but itās battery powered, so canāt put it out there till it actually sleeps in low power modeā¦
I donāt mean to complain that the spark doesnāt work for my particular situation, and I realize Maker Faire has people traveling, but any update on this topic would be greatly appreciated!
Low power mode seems pretty important for an IoT sensor, no? Any device that will be battery or solar powered stands to be very, very affected by the coreās inability to go into low power mode. @satishgn, power requirements needed during sleep worked as documented a while ago, but stopped working. Could the changes made to 0.2.2 firmware to do all the WiFi.off() and #include āspark_disable_wlan.hā stuff to work have broken low power modes?
Brianr, I have not looked at the wifi.off () power recently but I do know that deep sleep power is about 7-8ma.
Give me a couple of days to do some testing and Iāll report back with my findings. Like you, low power is important to me as well.
Thanks so much for taking the time to look into it, @peekay123. @kennethlimcp ran the simple test code that I posted and agreed with my findings. Doesnāt seem like anything has changedā¦
Let me say that we have heard you guys loud and clear and we discuss till late midnight, 2-3am on how we can resolve all these issues.
We are not asking for credit for the amount of work and time we spend but some issues requires lots of effort and testing to improve
