@Acrop, I actually had such spiky data already with the Electron, but not as many as with the Boron. After removing the outliers, I managed to get down to about 2 g scale reading precision.
In my case, the HX711ADC is creating many outliers which will bias an average value greatly. I can’t tell if this is due to the quality of its power supply or electrical noise in the amplifier or by bad shielded cables to the load cells. Anyway, I think it is pretty common to apply filters in digital signal processing, and I did this by using a median instead of just using an average. A median nicely gets rid of extreme values and therefore delivers pretty stable scale readings. I am actually surprised, that the HX711ADC library only provides an average and not a median function.
Therefore, I had to add myself a median function, as described in below code snippet. In this example, the median is calculated based on 100 instantaneous scale readings. Much less readings may also get already a stable result.
Below the wiring of the HX711 to the Boron (actually not really Boron, but the pins are the same) as well as a code snippet. I am using here the library HX711ADC (0.0.3).
I hope this helps.
#include <HX711ADC.h> //scale amplifier
#include <Arduino.h>
#include "math.h"
// HX711.DOUT - pin #A1
// HX711.PD_SCK - pin #A0
HX711ADC scale(A1, A0); // parameter "gain" is ommited; the default value 128 is used by the library
float scale_weight = 0;
int const num_scale_readings = 100; //number of instantaneous scale readings to calculate the median
float readings[num_scale_readings]; // create arry to hold readings
scale.begin();
scale.power_up();
delay(100);
scale.set_scale(22); //gain: this value is obtained by calibrating the scale with known weights
scale.set_offset(100000); //offset: this value is obtained by calibrating the scale with known weights
for (int i = 0; i < num_scale_readings; i++) {
readings[i] = scale.get_units(1); // fill the array with instantaneous readings from the scale
delay(100);
scale_weight = median(readings,num_scale_readings); //calculate median
Serial.println(scale_weight);
scale.power_down();
delay(10000);
//Following functions are based on "https://github.com/dndubins/QuickStats", by David Dubins
float median(float samples[],int m) //calculate the median
//First bubble sort the values: https://en.wikipedia.org/wiki/Bubble_sort
float sorted[m]; //Define and initialize sorted array.
float temp=0.0; //Temporary float for swapping elements
for(int i=0;i<m;i++){
sorted[i]=samples[i];
bubbleSort(sorted,m); // Sort the values
if (bitRead(m,0)==1) { //If the last bit of a number is 1, it's odd. This is equivalent to "TRUE". Also use if m%2!=0.
return sorted[m/2]; //If the number of data points is odd, return middle number.
} else {
return (sorted[(m/2)-1]+sorted[m/2])/2; //If the number of data points is even, return avg of the middle two numbers.
void bubbleSort(float A[],int len) {
unsigned long newn;
unsigned long n=len;
float temp=0.0;
do {
newn=1;
for(int p=1;p<len;p++){
if(A[p-1]>A[p]){
temp=A[p]; //swap places in array
A[p]=A[p-1];
A[p-1]=temp;
newn=p;
} //end if
} //end for
n=newn;
} while(n>1);
