Boron Devices Stop Charging deviceOS@1.5.0
@ccunningham,
I don’t think we have closed on this yet. I have a support ticket and am getting help from the Particle support folks.
  • If you are not going to use a USB cable to charge your Boron, you can leave the DPDM stuff out.
  • I think we made some progress on resetting the PMIC in this thread, worth taking a look as the command to reset the power configuration may help you with your Borons:
    New System BatteryCharge API deviceOS@1.5.0
I will keep you posted if I learn anything on a fix.
