analogRead problem
Hi @dega and @richlyon
This is unfortunately a known problem and the fix is already in place in the lastest "master" branch, so if you can build locally you can get the fix right now. I am sure that the fix will make it way to the "compile-server2" branch used by the web IDE when it is fully tested by Spark.
Just for reference, here is the thread where this got explored and fixed in "Odd analog readings (part 2)":
