Adafruit Neopixel Library [PORTED]
my setup is exactly like your picture above, except i also use the 5v to power the core through the vin pin. but that shouldn’t make any difference.
sounds like it could be a timing issue…
try the code from here, its very well tested and would be a good test for your LED strip…
