@HardWater, the ARE 5V tolerant as long as pull-up or pull-down resistors are not used. From Photon datasheet:
[1] FT = 5.0V tolerant pins. All pins except A3 and DAC are 5V tolerant (when not in analog mode). If used as a 5V input the pull-up/pull-down resistor must be disabled.
