XML and electron
Hello particle forum, thanks for the help in the past, I hope you can help me moving forward with my current project.
I am using a particle electron.
There is an XML site that contains a bunch of fields with statuses - like:
The XML gets updated from a separate web page (that I don’t have access to).
I need to have the Electron check this item and then run some functions based on the status.
I would love some advice in the best way to do this. Is there a way to avoid having the electron have to poll the XML site constantly?
Any and all advice is appreciated, please let me know if there is any further info I can provide!
Someone need to do the polling/checking.
You can have an app running that polls the XMl site at regular intervals and do a Particle.publish() or call a Particle.function()
Hi, I’m still trying to work this out. I’m trying to use the webhook example: https://docs.particle.io/tutorials/integrations/webhooks/#what-39-s-the-weather-like-
but I am trying to grab data from an XML site that has a lot of fields, like this:
<areas>
 <area name="Area 1">
    <item 1>
    <item 1 name="Name 1" type="Type 1"  currentStatus="Closed"/>
    </item 1>
    <item 2>
    <item 2 name="Name 2" status="Closed" />
    </item2>
    </area>
I need to grab, for example, item 2 status.
Help is greatly appreciated!
