I get prompts for either when I’m adding code.
Particle.variable reference shows it as capitals but elsewhere int is just used as lower case.
INT
is (roughly) a constant that tells the function Particle.variable()
how to treat the variable that you’ve provided a pointer to in the second parameter of the parameter list.
int
is a C key word that denotes a variable type.
You can create a variable by writing
int myIntVar;
but you can’t write
INT myIntVar;
For more info about INT
have a look at the open source repo
https://github.com/spark/firmware/blob/develop/system/inc/system_cloud.h
This is a great point, and I can see why they are confusing. We will eventually be removing the need for INT
and instead simply writing
int myvar;
Particle.variable("myvar", myvar);
Will be sufficient, with no need for &
which also adds confusion. Good to keep things simple!
