What is the Cellular LTE Band of the default carrier in Northern California
Who is the default carrier and what LTE band does it use in Northern California?
I have a Boron dev kit on order, and want to get a stronger LTE antenna for a remote sensing setup.
I’m planning on starting with the default carrier, Device Cloud and the onboard SIM chip.
Also, does anyone have a recommendation for an LTE antenna?
Thank you!
Welcome
https://docs.particle.io/tutorials/cellular-connectivity/cellular-carriers/
and from the datasheet
https://docs.particle.io/datasheets/cellular/boron-datasheet/#fcc-approved-antennas
Thank you! That tutorial had exactly what I was looking for.
Do you know where I can find the max power the LTE antenna can pull? I don’t see it on the datasheet…
5.00dBi peak gain for the antenna. (from the antenna page)
The SARA-R4 modem max transmit power is 23 dbm.
Thank you! Exactly what I was looking for
