I am currently developing an infrastructure to write apps that communicate with my Particle devices via the documented REST interface. One thing that I have written and tested is code to “ping” a selected device to see if it is on-line
(reference: https://docs.particle.io/reference/api/#ping-a-device)
The online documentation says that the Particle Cloud returns JSON as follows:
“online”: true,
“ok”: true
I have observed this to be correct, as well as “online”:false when the device is offline. But: what does the other attribute “ok”:true mean? Well, of course, if “ok” is true, it is pretty obvious what it means. But is “ok” ever false? If so, what, specifically, would cause this? I want my apps to correctly and fully respond to a device ping. However, the “ok” attribute is not documented and I was wondering if anyone has further information.
