This is driving me nuts. Can anyone tell me why the following code won’t compile?
ftoa (mb, res, 1) ;
#ifdef NEX
Pressmb.setText (res)
#else
setCursor (18,11) ;
lcd.print(res);
delay (100) ;
lcd.println();
delay(100);
#endif
// Pressure tendency display:
#ifdef NEX
if (P0 > P2) // **** Compiler error on this line ****
PresTend.setText ("+") ; // rising pressure
if (P0 == P2)
PresTend.setText (" ") ; // needed for correct spacing
ftoa (P0 - P2, res, 2) ;
PresTend.setText (res) ; // show the change
switch (Ptend)
case (1):
PresTend.setText ("/ ") ;
break ;
case (2):
PresTend.setText ("\\") ;
break ;
case (3):
PresTend.setText ("_ ") ;
break ;
case (4):
PresTend.setText ("v ") ;
break ;
case (5):
PresTend.setText ("^ ") ;
break ;
case (6):
PresTend.setText ("_/") ;
break ;
case (7):
PresTend.setText ("\\_") ;
break ;
case (8):
PresTend.setText ("/^") ;
break ;
case (9):
PresTend.setText ("^\\") ;
break ;
default:
PresTend.setText ("? ") ; // should never happen
} // end switch
#else // for Sparkfun LCD
setCursor (8,12) ;
if (P0 > P2)
lcd.print ("+") ; // rising pressure
if (P0 == P2)
lcd.print (" ") ; // needed for correct spacing
lcd.print (P0 - P2) ; // show the change
delay (100) ;
switch (Ptend)
case (1):
lcd.print ("/ ") ;
break ;
case (2):
// Back slash hack - col. no. 13 line no. 12
lcd.print (" ") ; // clear the previous line
lcd.drawLine (12*6, 12*8, 12*6+4, 12*8+6, 1) ;
break ;
case (3):
lcd.print ("_ ") ;
break ;
case (4):
lcd.print ("v ") ;
break ;
case (5):
lcd.print ("^ ") ;
break ;
case (6):
lcd.print ("_/") ;
break ;
case (7):
lcd.print (" ") ; // clear the previous trend line
setCursor (14,12) ;
lcd.print ("_") ;
break ;
case (8):
lcd.print ("/^") ;
break ;
case (9):
lcd.print ("^") ; // clear the previous line
lcd.drawLine (12*6, 12*8, 12*6+4, 12*8+6, 1) ; // "^\"
break ;
default:
lcd.print ("? ") ; // should never happen
} // end switch
delay (100) ;
#endif
This gives this error:
/src/weatherlcd1.cpp:1209:8: error: expected ';' before 'if'
if (P0 > P2)
But if I comment out the first #ifdef block at the top of this code
ftoa (mb, res, 1) ;
/* #ifdef NEX
#else
setCursor (18,11) ;
lcd.print(res);
delay (100) ;
lcd.println();
delay(100);
#endif
#ifdef NEX
if (P0 > P2) // Now no compiler error on this line
it compiles fine. I have literally been staring at this for hours now.
