Hi There, this is my first post so I hope that it is in the correct category, if not please shift it as appropriate.
I am wanting to store an array of unix_time:data every 15 minutes on my electron and publish this using a webhook once every 24 hours.
ie
unix_time_1:value
unix_time_2:value
unix_time_96:value
The receiving server requires the time in TIME_FORMAT_ISO8601_FULL, which is fine I can convert the time stamps on the electron and create the JSON array with time as a string just before publishing it. but this is very wasteful on bandwidth, and also available RAM to create the ~100 time stamps.
Reading up on the mustache documents it is possible to use Lambdas.
http://mustache.github.io/mustache.5.html
Lambdas
When the value is a callable object, such as a function or lambda, the object will be invoked and passed the block of text. The text passed is the literal block, unrendered. {{tags}} will not have been expanded - the lambda should do that on its own. In this way you can implement filters or caching.
Template:
{{#wrapped}}
{{name}} is awesome.
{{/wrapped}}
Hash:
"name": "Willy",
"wrapped": function() {
return function(text, render) {
return "<b>" + render(text) + "</b>"
Output:
<b>Willy is awesome.</b>
This seems to be exactly what I want to do.
Q: Is this possible and how do I format my “script.json” file to include the functions and load it up to particle.
Thanks and Regards
Marshall
